Old 14-03-2008, 12:55 PM   #1 (permalink)
raksrules's Avatar
Default USB Cable Discharges instead of Charging the cell !!
I own a Sony Ericsson w800i and recently due to lack of availability of charger, i took the USB cable from my friend in office (she own a K550i). I kept my phone to charge it through the USB cable. But what i observed was completely different. It was showing on screen as if it is charging the phone. But in reality the battery was getting discharged. She also tried charging her phone with that USB cable and her phone also got discharged completely after a few hours. How did this role reversal happen ???
raksrules is offline
Old 14-03-2008, 12:59 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: USB Cable Discharges instead of Charging the cell !!
plug ur phone to datacable and see if ur optical mouse's light is turned on. . . if you dont switch on the main power source, ur cell's battery will be used to light up ur optical mouse and other LEDs like keyboard. etc
Gigacore is offline
Old 14-03-2008, 01:02 PM   #3 (permalink)
unni's Avatar
I have a K810i. I have seen this in my phone also. I tried in my office PC, and instead of charging through USB, the cell battery was discharging. At first I didn't believe this. So, I started monitoring battery charge using Float's Mobile Agent. Within 15 minutes, about 5% was gone. I thought it was because the PC I use is very old. It doesn't have any optical mouse.
unni is offline
Old 15-03-2008, 11:50 AM   #4 (permalink)
hell boy
i dont think so my phone is charged under phone mode and in mass storage also it gets charged but the charging time is very much than using a charger my phone is w200i
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 17-03-2008, 09:46 AM   #5 (permalink)
raksrules's Avatar
For my w800i there are no different modes available. Just connect the phone and it shows as a removable drive and also starts charging(actually discharging) the same.
Old 17-03-2008, 10:05 PM   #6 (permalink)
hailgautam's Avatar
The phone will get discharged when automatic USB internet connection is enabled.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 17-03-2008, 11:34 PM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
1) W800i will NOT charge unless its device drivers are loaded in the computer.
2) Any phone will discharge thru USB if the cable is of cheap quality and doesn't haf a Diode in it to check the discharge (to prevent reverse flow of current).
infra_red_dude is offline
Old 18-03-2008, 10:11 AM   #8 (permalink)
raksrules's Avatar
Do you mean that
PC Has drivers -> Phone Charges
PC Does not have drivers -> Phone Discharges
I dont think so that possible because the USB port has got power and i will charge the attached device (if possible) if it is supposed to do so.
BTW i tried the same in my friend's office PC where the drivers are installed but still the cell got discharged. The cable that she is using is the one that she got from in the phone box.
Old 18-03-2008, 09:14 PM   #9 (permalink)
Wire muncher!
Yes, for previous generation cellphones the Windows drivers need to be loaded (I dunno about Vista, but yes in XP). Jus try to boot up the PC and goto BIOS. Now plug in the cable and see if the phone charges. Tho the battery icon animates the charge will remain same.
Its possible that the diode in the original cable is damaged or has broken in (not as in damaged, but electrically broken in). None of the cables I've seen (original) haf this problem.
All Cellfones to Have Same Charging plug iMav Technology News 26 25-09-2007 12:46 PM
suggest a cell with edge and comes along with data cable in 5-6K almighty Buying Advice 6 27-07-2007 10:22 PM
Cell Phone Charging pop143 Mobiles and Tablets 1 29-06-2006 10:49 AM
Mobile Charging through data cable help !!!!! expertno.1 Mobiles and Tablets 7 23-08-2005 09:23 PM
Cable or BT connection for cell to laptop??? infra_red_dude Laptops and Netbooks 2 08-02-2005 05:59 AM
