Re: w800i earphones !!! Pleasehelp
Hi.. If the problem is the same with both fast ports, then, check the mobile connector i.e., the interface to connect the fast port to the mobile. Check the metal plates. Sometimes, this would happen when they catch dust. This happens to me and I have to clean them with a pin or something.
Hi.. If the problem is the same with both fast ports, then, check the mobile connector i.e., the interface to connect the fast port to the mobile. Check the metal plates (I am not talking abt the fast port but the interface on the mobile.). Sometimes, this would happen when they catch dust. This happens to me and I have to clean them with a pin or something.
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Reason: Automerged Doublepost
