Originally Posted by alsiladka
Download the DivX mobile software and use the DivX converter to convert your videos using the QMobile profile.
If you do not have the DivX converter, you will have to look for some other convertor. But DivX converter is cool, just drag and convert. And the quality is also awesome.
It will give Bogus quality
@dead
after taking your considerations , i ran across a number of tests .....
the codecs were H.263 , H.264 , Theora , Divx/Xvid , the results are :-
H.264 is far better than h.263 and divx at lower bitrates (tested at 100 kbps)
theora at 100 kbps is close to h.264 say 78% close (for 100 kbps)
but h.264 is better .
CORE player of symbian has an inbuilt codec known as CoreAVC (which is the worlds fastest H.264 decoder) so you will not have any problems .
BUT since Core player doesn't recognizes stereo of the he-aac v1/v2 profiles (mentioned at the site and tested by me) , you should use ogg vorbis .
Conclusion
Video Codec = H.264 @ 100 kbps
Audio Codec = Ogg Vorbis @44-48 kbps
Results are very excellent and u get 1min video in 900-1000 kb only at far better quality than divx or xvid .....
Tested on N70 and Core Player 1.2
Encoder used = Mediacoder
I can even post the experimented video files if u want
Thanks
Regards.....
Expertno.1
