Old 07-03-2008, 08:37 AM   #1 (permalink)
True Techie
nithinks's Avatar
Default Increase earphone volume in N72
Hello members,
Can anyone tell me how I can increase the volume of earphone? It is too low even if I set the volume to max.Should I change the file format from .mp3 to something else like .aac ?
Thanks
http://www.mytechyard.com/
nithinks is offline
Old 07-03-2008, 12:23 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Increase earphone volume in N72
Dump the default player and use MP3Player from Viking.
krazzy is offline
Old 07-03-2008, 06:05 PM   #3 (permalink)
True Techie
nithinks's Avatar
But is it recommended?
nithinks is offline
Old 07-03-2008, 06:45 PM   #4 (permalink)
SpamBoyVtek's Avatar
U can also use POWERMP3
SpamBoyVtek is offline
Old 07-03-2008, 07:39 PM   #5 (permalink)
True Techie
nithinks's Avatar
my question is..... does it cause any damage to cell? (by forcefully amplifying)
nithinks is offline
Old 07-03-2008, 08:01 PM   #6 (permalink)
speedyguy's Avatar
no it wont...just make sure at any time ur music does not sound distorted due 2 volume
Enjoy~1
No Pain...No Gain
speedyguy is offline
Old 07-03-2008, 10:12 PM   #7 (permalink)
expertno.1's Avatar
Originally Posted by nithinks View Post
Hello members,
Thanks
Yep you will notice slight change in volume if u switch to aac but not enough to fulfill what you want .
You better get new earphones which provide louder sounds , like the in-ear type ones or the very famous ep-630 .
I too am using it and find the volume twice to that of the normal nokia earphones .
if you dont want to get the new earphones .....
get Oggplay from http://symbianoggplay.sourceforge.net/
it has -24 to +24 db sound amplifying range (greater that any other symbian players) ...... you can only make the sound loud as far as it isn't distorted.....
but i would suggest to get rid of nokia earphones
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 07-03-2008, 10:31 PM   #8 (permalink)
Techtree Reviewer
krazzy's Avatar
Yes getting a pair of noise cancelling earphones is recommended as well, not because they make music louder, but because they reduce surrounding noise and hence the music is heard clearly without the need of increasing the volume too high.
Using MP3Player won't cause any harm to the phone.
krazzy is offline
Old 07-03-2008, 11:52 PM   #9 (permalink)
expertno.1's Avatar
The sound does depends upon the modulating signal through the earphone , but even earphones have band pass filters or you can say perform louder in lower modulating signals .
Thanks
Regards.....
Expertno.1
Old 08-03-2008, 10:31 AM   #10 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
+1 for ep630, i am using it with N72 and i have even using public transport i don't have to pump the vol more then 80%, the are sort of noise canceling and in canal type
abhasbajpai is offline
Earphone digitizen Mobiles and Tablets 4 01-01-2008 01:36 PM
Required: Software to increase volume of DivX Video File prajneet Software Q&A 2 01-11-2006 07:48 PM
how to increase audio volume hansraj QnA (read only) 1 18-10-2006 08:05 PM
increase nok 6600 volume... tweety_bird_bunny Mobiles and Tablets 1 24-09-2005 02:03 AM
If Increase the RAM Then the System speed will increase muralikrishnan QnA (read only) 9 23-09-2005 03:52 PM
