| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
LinkBack (1) | Thread Tools | Display Modes |
I'm planning to buy a new laptop: DELL XPS 1530 with a budget of around Rs.80,000/- the configuration I've selected is : Total Price : Rs 84,611.94 R510205 - Dell XPS M1530 Laptop Base System Intel(R) Core(TM)2 Duo Processor T7500 2.2 GHz, 4MB Cache, 800 MHz FSB Operating System Genuine Windows Vista(TM) Home Premium Dell Services: Installation Basic System Installation ExpressCard Slot, (DOES NOT SUPPORT PCMCIA CARDS) Dell(TM) Support Center Dell(TM) Keyboard with Touchpad (English) Integrated 10/100 Fast Ethernet Dell(TM) Travel Remote Control Noise Isolation Ear Buds External USB modem (WW) RJ-11 Modem cable (AP) Dell(TM) Media Direct Dell(TM) PC-Restore Display 15.4" UltraSharp(TM) Widescreen WSXGA+ (1680x1050) TFT Display with TrueLife(TM) Memory 4GB ( 2 X 2048MB ) 667MHz Dual Channel DDR2 SDRAM Audio Solution Integrated Sound Blaster Audigy ADVANCED HD Audio Software Video Card 256MB NVIDIA(R) GeForce(R) 8600M GT Hard Drives 160GB SATA 7200RPM Performance Hard Drive Hard Drive Partition Hard Drive Partition, Primary Size 60GB in C Drive, Remainder in D Drive Internal Optical Drive Internal 8X DVD+/-RW Combination Drive with dual layer write capabilities Roxio Creator 9.0 Microsoft(R) Works 8.5 (Does Not Include Microsoft(R) Office 2003/2007 Software) McAfee(R) Security Center(TM) – 30 days trial Bluetooth Module Dell(TM) Wireless 355 Bluetooth Module Wireless Network Solution Intel(R) 4965AGN Wireless-N Mini-Card Color Kits Midnight Blue LCD display with Integrated 2.0 mega pixel web cam Palmrest with Fingerprint Reader Finger Print Reader Software Adapter 90W AC Adapter 6-cell Lithium Ion Primary Battery Carry Case Dell(TM) Nylon Backpack Shipment Box for Case Dell Services: Hardware Maintenance 1-year XPS Premier Service with 1-year complete cover 1 Year Priority PC User 24x7 Support (Round-The-Clock Technical Assistance) 24x7 Telephone Technical Support Hotline: 1-800-425-2066 Regional Support Within Asia Pacific Countries For Laptops Total Total Amount Rs72,408.00 Total Amount Before Tax Rs72,408.00 CD/CVD/Excise Duty Rs8,949.63 VAT - 4% Rs3,254.31 Total Amount Before OCTROI TAX Rs84,611.94 OCTROI - 0% Rs0.00 Total Tax Rs12,203.94 Total Amount After Tax Rs84,611.94 is this configuration fine??? is there any way to get more discounts?? what is CVD tax??? what is the difference b/w Basic System Installation and classic system installation??? i've configured this system keeping 'desktop replacement' in mind. so battery life and weight does not matter much for me. waiting for expert opinions..... |
#2 (permalink) |
Google Bot
Do yourself a favour, wait for Dell to include t8x00 and newer 88xx/9x00 gpus in their customisation options.. The 45nm proccy upgrades should be done soon.
My new blog: www.pathikshah.com |
#3 (permalink) |
thanx for replying...
but how soon do u think this upgrades will be made???? already i've waited for more than a month to happen... now i really need this laptop.... |
#4 (permalink) |
Max, a month wat with Apple out with Penryn stuff, it would not be long
The real and only freedom is Public Domain. Everything else in unfree! Even those who claim to be the self styled evangelists of freedom are not free because freedom cannot be forced by any means! |
#6 (permalink) |
Wandering in time...
Also it much better if you can add 2GB RAM on your own rather than taking it from Dell itself.
Check to make sure it does not void warranty. If you want this laptop to a gaming laptop then wait for better gfx cards to arrive on laptops.
Integrate Yourself With The Latest Happenings..... www.ankur-gupta.com/blog |
#7 (permalink) |
i like gaming but i'm not very much into it...
all i want is a high performance desktop replacement which could last around 3 years... also should i spend more on dell services???? i've kept it at lowest priority... only 1 yr warrenty only... |
#8 (permalink) |
Bond, Desi Bond!
if you are not a hardcore gamer, it makes no sense to buy XPS series. Better go for the Dell 1500 series with the same hardware and you will save more money.
you can also check hp dv series. And yes, Go for Penryn based laptop. Being 45nm core, it will be more power efficient and powerful with higher performance-per-watt. |
#9 (permalink) |
XPS has better flaunt value & looks out of the crowd...
i really like its design... actually i have a very old comp cant run any of the new games so i had to give up gamming... & when i'll get this new lappy, crysis will be the first game i'll try on it... |
#11 (permalink) | |
Bond, Desi Bond!
can't say about 3 yrs as the games and apps are getting bigger and bigger every month. |
#12 (permalink) |
i dont have any relatives or friends outside india...
so no luck... some1 plz tell me that should i spend more on dell services??????? is it worth spending 8k extra to get 2 yr complete cover warrenty??? there is no option for 8800GT so i'm going with 8600GT... Last edited by v_joy; 27-02-2008 at 11:05 PM. Reason: Automerged Doublepost |
#13 (permalink) |
Rebooting
http://store.apple.com/1-800-MY-APPL...hG6x134/2.?p=0
add some goodies like a better faster HDD an Apple care plan then buy some RAM from local store to run at full 4 GB if you wish which would made it Rs. 92k all
rebooting ChotoCheeta.com |
#15 (permalink) |
Bond, Desi Bond!
yes. it is worthy to get 2 yr warranty.
I have a thinkpad with 3yr international warranty and after first year, Display, keyboard, motherboard had to be replaced. Better be safe than to be sorry. |
#16 (permalink) |
Rebooting
Now days you can always have frnds frnd or some one at US
#18 (permalink) |
Bond, Desi Bond!
there was a high voltage and donno how, laptop started behaving weirdly, rednes in display, problem with keys etc. Sent it to support and they replaced LCD, motherboard and Monitor as they were effected by the spike.
#19 (permalink) |
hey choto do u know whats CVD tax????
i thought laptops r not affected by power surges.... is it a rare case????? has anyone else here has experienced this???? Last edited by v_joy; 27-02-2008 at 11:15 PM. Reason: Automerged Doublepost |
#20 (permalink) |
Another Brick in the Wall
The taxes you need to pay are: excise duty, VAT and octroi taxes. You need to pay CVD as the Dell is being imported (from China).
I have a Mercury Spike Buster for my MacBook. It's better to be safe than sorry. You're investing Rs 80k+, another 2k on misc stuffs hardly matters. By the way, ses if you can get an Apple MacBook Pro from the USA. The base model costs Rs 80,000 and has far better features and better configuration than this Dell. Seriously try to get from USA.
I Love Photography. I Love Aperture. I Love Mac. |
#21 (permalink) |
Bond, Desi Bond!
^^ macbook pro is officially the fastest Vista laptop
FYI, Dell snaps Penryn chips into Precision M6300, X9000 included http://www.dell.com/content/products...en&s=bsd&cs=04 Last edited by desiibond; 28-02-2008 at 09:46 AM. Reason: Automerged Doublepost |
#23 (permalink) |
The Smaller Bang
make that one fastest branded laptop. Nothing beats the Assembled laptops you can build yourself if you are in the US.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#25 (permalink) |
its not that i dont like macbook pro, but i'm not intrested in it mainly becoz its very expensive in india and neither can i get it from abroad, besides (i dont know why) my sister is not comfortable with anything other than windows...
BTW what other CDs does dell provide with the laptop besides original windows installation CDs???? does dell have windows recovery feature (which is done by pressing F11 key)??? are there any other hidden costs??? like delivery charges...etc.... how much time do they take for delivering it to home??? |
#26 (permalink) |
^^ Discs are
A second disc which comes with the bloatware they put on PCs. This is prolly the disc with drivers Microsoft Works or MS Office depending on what you take,
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/81234-dell-xps-1530-80-000-configuration-analysis-plz-help.html
| Posted By | For | Type | Date | |
| Info.com - ww 81234 - www.Info.com | This thread | Refback | 29-08-2010 10:24 PM | |
| Dell XPS 1530 Graphic Card Problem? | Rahuldhanpat | Graphic cards | 10 | 09-03-2008 02:26 AM |
| Dell inspiron 1530 questions. | gowtham | QnA (read only) | 11 | 27-01-2008 07:41 PM |
| Dell inspiron 1530 questions. | gowtham | Mobiles and Tablets | 3 | 25-01-2008 05:48 PM |
| Analysis Software | tukaibatman | Software Q&A | 3 | 21-10-2004 01:34 PM |
