Originally Posted by infra_red_dude
For mids and lows you haf custom acoustics. For bass - enabling the megabass equilizer set will require applying just a patch! (Tho it won't come with that flashy megabass blue logo, but what it delivers is megabass since its only an eq config. internally).
wat u mean by this is that the hardaware in k790i supports megabass.. right?? in that case, i shd hav megabass after applying custom patches..
Originally Posted by desiibond
after some searching through the internet, I found this:
The music player is same as "walkman" phones, but stripped of walkman branding and "megabass" equalizer... it is stil very
good, u can make playlists,et al.. The manual equalizer is still there.. also you can play .rm songs too!
thanks for the effort desiibond.. much apreciated!
also, can someone tell me wats the difference between k800 n k790?
