Old 26-02-2008, 11:38 AM   #1 (permalink)
The real Bond
yogeshm.007's Avatar
Question W580 Or 5310 ???
Hi
I am planning to buy one of SE W580 and Nokia 5310. Can you please suggest me which one is better? For me, 5310 only has good music capabilities and a bit better software compatibility going for it, otherwise W580 seems a good all round phone with much better firmware. My dad has Z550i and I'm its music sounds good to me, just its bases are mellow.
(PS: I'm planning to have a 4 GB card installed also)
Any help is appreciated...
Thanks
yogeshm.007 is offline
Old 26-02-2008, 12:36 PM   #2 (permalink)
Default Re: W580 Or 5310 ???
i think w580i is better than 5310
w580i looks stunning it has good features and excellent music quality as well
but just check its keypad before going to buy. i heard it breaks easily
5310 is only good for the music while w580i is overall good and available in different colors
Give the best, Give up the rest
choicefreedom2000 is offline
Old 26-02-2008, 12:38 PM   #3 (permalink)
Google Bot
Pathik's Avatar
w580i.
Pathik is offline
Old 26-02-2008, 12:54 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
I will stay away from 5310. It's too tiny.
I actually went to buy this phone but ended up buying motorok E6. I didn't take W580i as I never liked the slide up interface and walkman phones are too overpriced.
eg: k550i and w610i have same hardware but a 3k price difference between them only due to walkman branding
If you can pay 12k, go for N73me or K790i. You will be amazed by the quality of K790i, a true winner.
desiibond is offline
Old 26-02-2008, 01:25 PM   #5 (permalink)
The real Bond
They are priced higher all right, but they also bundle extra features. e.g. referring to your example W610 comes with more memory and with portable stereo speaker; not that I want those
I just wanted your opinion about 5310/W580 because I was not sure about real difference between music quality of these phones. I have made my mind for W580, just wanted to be sure.
About the keypad problem, I had contacted SE customer care and they said that the problem has been solved in newer models and I think I can trust them.
Thanks
Old 26-02-2008, 01:53 PM   #6 (permalink)
Gracias Senor
dreams's Avatar
Close ur eye's n go 4 w580i..I am havin the same and the keypad is very strong. no issues til now.
Pros - Walkman, side lights, shake control, can modify anythin 2 ur taste(flash menu's, walkman skins, icons, custom menu's).
Cons - Battery life, no flash.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 26-02-2008, 01:57 PM   #7 (permalink)
The real Bond
Can you throw some light on battery life?
Old 26-02-2008, 02:08 PM   #8 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^^ Okay. My vote goes to W580i. I tested both and i feel that W580i is much much better as overall package. Only thing that is good about 5310 is it's 9.9mm thick. IMHO, It's a ladies phone. Being slim, it has 850mAh battery and the display is 16M color and eats lot of battery. don't fall for the 18hr music playback thing. That is for ideal playback where you play 128kbps mp3 with minimal use of display and minimal skips.
Old 28-02-2008, 10:00 AM   #9 (permalink)
Sangeet Premi
2kewl's Avatar
W580i for sure! Excellent phone
2kewl is offline
Old 10-03-2008, 10:58 AM   #10 (permalink)
The real Bond
Ok, got a new W580 for 10.1k on Saturday.
BTW, i've one more question for you. Can i attach normal headphones with it? My brother has one by Tokshu (or something like that; one which covers the ears; with more than average overall performance) and insists on using them with phone. I'm not sure of power rating of the headphones. I'm still not allowing my brother to plug them into the mobile. Can anybody help me in this?
Thanks.
Old 10-03-2008, 11:02 AM   #11 (permalink)
Wire muncher!
infra_red_dude's Avatar
You can always try. You can't attach headphones whose impedence rating doesn't match with the source.
The best way is to go ahead and test it
infra_red_dude is offline
Old 10-03-2008, 02:08 PM   #12 (permalink)
The real Bond
I can try, but can i damage my phone like this?
Old 10-03-2008, 03:02 PM   #13 (permalink)
Rockin g33k
dreamcatcher's Avatar
no u cant...it may drain the battery more and may affect the battery life in the long run(in mayb 3 years)....but it wont harm ur phone
My blog-www.rayarunava.com
dreamcatcher is offline
Old 10-03-2008, 03:49 PM   #14 (permalink)
The real Bond
Thanks, i'll try now
Tutorial: Flash S500 to W580 a_k_s_h_a_y Mobiles and Tablets 25 18-12-2008 05:21 PM
5310 Xm srikanth.9849671439 Mobiles and Tablets 2 07-02-2008 08:30 AM
W810i or 5310?? arun_cool Mobiles and Tablets 20 26-01-2008 07:52 AM
THE Nokia 5310.... cooldudie3 Mobiles and Tablets 10 03-01-2008 07:51 PM
