Old 26-02-2008, 09:19 AM   #1 (permalink)
Visitor
guest's Avatar
Default Can i replace my N95 body
Hi,
I'm using a n95 but you see since i'm aregular traveler and a very careful phone user well my n95 body has all the paint gone off anf tonnes of scratches and all the silver pain on the keypad gone. You'll have to see it to believe it how bad it is. I love the phone after the latest firmware update it just runs too great and i dont want to get rid of it. I just wanted to know if it is possible to get the whole body changed?? and Approx how much will it cost??
guest is offline
Old 26-02-2008, 02:07 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Can i replace my N95 body
to change the whole body u'll hafta give the fone to the Nokia Care ppl (i.e if u want the original body).
else u can try the grey market and get the cheap quality ones for 200-500 bucks.
original one sud cost bout 1-1.5k
hellgate is offline
Old 26-02-2008, 04:23 PM   #3 (permalink)
Visitor
guest's Avatar
oh cool can i change the whole body?? including back panel and keypad?? it'll be only 1.5k??
guest is offline
Old 26-02-2008, 04:36 PM   #4 (permalink)
M$™ Certified Spammer
entrana's Avatar
u can change the keyboard and if the back panel is the sliding thing u can change that too. its better to get it from nokia dont bother for custom ones they may.. damage
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 26-02-2008, 04:52 PM   #5 (permalink)
Visitor
guest's Avatar
No basically i want to change the whole body. the plastic on the slider, the keypad and the back panel where the battery is kept. Wanted to know if it was possible and approx how much will it cost
guest is offline
Old 26-02-2008, 05:27 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
just speak with the Nokia Care ppl and they will let u know how much the whole thing will cost u.
hellgate is offline
Old 26-02-2008, 07:18 PM   #7 (permalink)
Visitor
guest's Avatar
Thanks alot
guest is offline
Should i replace the new cpu fan? New CPU / Motherboards 6 03-01-2008 07:58 AM
how to replace digit dvd? Dishant Chit-Chat 1 23-12-2007 06:58 PM
Can I Replace Laptop HDD Myself ? dr_jimit Hardware Q&A 4 30-08-2007 05:27 PM
How to replace forced .tk favicon titun QnA (read only) 3 05-12-2006 10:27 AM
