Old 22-02-2008, 07:51 PM   #1 (permalink)
Default NOkia n72 not detected,help!!
Hi,
My friend bought a nokia n72 in january . He has installed the bundled pc suite on his computer(p4 , 256 mb ram , windows xp home edition sp2).The problem is that the pc suite does not detect the phone. please help me solve my freind's problem.
slater007 is offline
Old 24-02-2008, 10:08 PM   #2 (permalink)
Mobile Freak
reddick's Avatar
Default Re: NOkia n72 not detected,help!!
Uninstall d PC Suite n restart ur PC
Again install PC Suite n connect d data cable only whn it says to do so...
After that connect it with ur phone...It will definately works
Perhaps it works 4 me...So may b it helps u too
Hope 4 d best n Do d right :)
reddick is offline
Old 24-02-2008, 11:09 PM   #3 (permalink)
Tech.Masti's Avatar
download latest PC suite and try
Tech.Masti is offline
Old 25-02-2008, 09:31 AM   #4 (permalink)
Ethan_Hunt's Avatar
Check under device Manager if all the drivers for the phone have been picked up correctly.While connecting the phone make sure you select it in PC Suite mode instead of data transfer.To verify correctly if it's been detected or not check under Nokia Phone Browser folder(in My Computer) & see if the model is listed.
V for Vendetta
Ethan_Hunt is online now
usb not being detected by any pc !! abinesh Hardware Q&A 5 15-06-2007 03:03 PM
HDD not detected sometimes pushkaraj Hardware Q&A 4 23-02-2007 08:07 PM
WD 80 gb ata hdd not detected by RH9 choudang Open Source 3 27-08-2006 10:53 AM
HDD not detected rahul_becks23 Hardware Q&A 7 25-07-2006 09:37 PM
