Old 22-02-2008, 05:39 PM   #1 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default need help for Nokia Map
Hi,
I connected my n95 8gb in data transfer mode and then started the Nokia Map in my pc. When the application starts it says "No storage medium detected.Connect your device to your computer via USB using data transfer mode or insert Memory card" Any help?
Previously i used the same without problem with my N80IE.. any help?
the.kaushik is offline
Old 22-02-2008, 06:46 PM   #2 (permalink)
Default Re: need help for Nokia Map
Have you tried it on other pc?
Head Banger is offline
Old 24-02-2008, 01:53 PM   #3 (permalink)
no, but why?
