17-02-2008, 06:41 PM
Help !! I have bricked my nokia 6233 while updating firmware
Guys i need your help....
i wanted to update my nokia 6233 firmware but with my crappy computer i delayed and atlast iu cudn't wait any longer.....
while it was updatiung the firmware my system crashed and now the mobile is not at all booting......
its inside warrenty and going to go to service center soon....in the mean time any way i can do it on my own ??? Also is it repairable ??
It has survived several falls and 5 min under water recently......
17-02-2008, 06:44 PM
Re: Help !! I have bricked my nokia 6233 while updating firmware
not sure!!
it has nothing to do with bricking the firmware
17-02-2008, 07:09 PM
Google Bot
Try the updation process again..
17-02-2008, 09:58 PM
=--=l33t=--=
If you can't get it to start up, chances are it is dead. You will need to take it to the service center where they will re-flash the firmware for you.
They will charge you quite a bit, there is nothing you can do really.
Homer: God bless those pagans.
17-02-2008, 10:16 PM
get it to the nokia care center, they will solve it for u at a "nominal" cost
17-02-2008, 11:39 PM
NP : Crysis
yes, it is definitely repairable...but they will charge u for it b'coz bricking isn't generally covered by warranty
18-02-2008, 10:10 AM
@pathiks....i tried connecting the data cable but it is not even recognising the mobile as it is switched off and not starting
so i will be charged fee for that....can i then say it was not my fault and say it just went off.....and then repair it in warrenty for free....
also if they are able to do it then we must also be able to do it right ??? Anyone knows the procedure ??
18-02-2008, 07:04 PM
today i gave it to nokia care and they asked 1 day time.....
21-02-2008, 10:22 PM
the guys at the nokia care center are nuts....
they were delaying and delaying repeatedly.....they thoroughly checked my moblie and found out that water had entered my mobile...  so they say it is not under warrenty....
also they say it has software prob(obviously firmware)  and also some hardware prob...
i was a bit skeptical about what they are saying....so i brought my moblie back without repairing...
now i want to know that if water has previously entered but mobile working fine after that....is there any chances of hardware prob occuring ???
also if anyone knows how to flash the firmware without even mobile starting..please tell me....
thinking of trying another nokia care center tomo to see what they have to say....
22-02-2008, 12:19 AM
Techtree Reviewer
^^ Welcome to India.  This is how mobile service centres work here. Whatever the problem may be, they'll either say it has water in it (even though it didn't had the slightest chance to get it) or has a software problem and needs formatting. I think these are the only two things they're taught while training.
22-02-2008, 05:25 AM
Commander in Chief
Actually, he has those two issues exactly. His post says his mobile was skinny-dipping for 5 (?) minutes. And then he bricked it with an update via a slow system (With Windows  ).
So those guys are right.
Harsh J
www.harshj.com
22-02-2008, 07:45 AM
Maybe ur phone battery is down. Charge the battery through another's phone and try to install firmware again.
If ur phone is still not detected by comp. maybe boot data of phone is corrupt
Then the last option is to replace hardware.
22-02-2008, 11:11 AM
The nokia care guys are right..u have to get it serviced..even if paid.. as soon as possible..bcoz even the slightest presence of water inside can damage ur circuits.It will cause a problem sooner or later..so better u get it serviced and after all its ur mistake not there...
22-02-2008, 01:15 PM
Techtree Reviewer
Its things like these that leads me to believe miracles really do happen. However I did miss the fact that his mobile indeed took a dip. However my friends SE J230i didn't. Even though he was forced to believe that his phone indeed went under water. And then pay for it.
22-02-2008, 01:29 PM
Wire muncher!
I dunno about nokia phones but in SE phones, water intrusion can be detected. All those of you SE phone owners can open up the battery and see a rounded rectangular white patch (usually near the terminals).
Its something like a phase-change material. When Water comes in contact with it, the white patch develops pinkish-red spots and thats how the service center guys detect water related problems. A solution is to tape/seal it so that water doesn't come in contact with it!
22-02-2008, 02:31 PM
thx for ur views guys....
now my mobile is not starting or detected....so any of u guys know how the nokia people load the firmware in this position ??? there is enuf charge in battery
but after i dropped mobile in water i dint turn it on and let it dry for 2-3 days.....then i started and it worked very well....so how can the hardware prob(which they say is there) occur  if so it wudnt have worked well after that right ????
also the nokia care people seem sticking onto the fact that mobile under water so major probs and no warrenty......they wudnt listen to me if i try saying the firmware was the one not allowing the mobile to start and try loading the firmware and see if it works......
2 of my frnds had probs along with me when we were on tour :
one wetted his mobile in beach and then turned it on....so it went dead cos of short circuit or something.....
another one had n91 and he dropped mobile and the side menu and lock button were not working very well....he gave it to service center and they charged Rs.1500 for those 2 buttons  so i am afraid to give it to them for repair as they keep telling no warrenty and looks to charge a hefty amount....
22-02-2008, 03:14 PM
respect mah authoritah!!
so nokia not that good at customer service after all. show this thread to all nokia fans
HP DV6 1319tx
N82 8GB(black)
Sony Cybershot DSC T500
Jabra BT3030
PSP phat(5.00 m33-6)
22-02-2008, 03:29 PM
Techtree Reviewer
^^ Don't get excited. Thats the case with all service centres in India, regardless of the manufacturer.
23-02-2008, 10:35 AM
#19 (permalink)
23-02-2008, 11:39 AM
#20 (permalink)
TEE HEE! This happens not only in India but any of Nokia's crappy repair centres.I highly doubt what kind of people they have working out there.The contact centre that I work for is a highly reputed mobile company in Australia & I have seen many of the time our customer's complaining that the repair centre claims their handset has incurred moisture damage or physical damage even though there wasn't a remotest possiblity of water entering it.
V for Vendetta
23-02-2008, 11:54 AM
#21 (permalink)
i can add a bit
EROM goes dead then phone is nuts .. !
Fools at Service Center don't know how to fix anything but only Reflash Firmware
Then can Reflash Firmware only when phone boots .. when EROM is done for .. no way to boot ..
it must have special boot script mode to start phone .. also you will need a cable that can generate current and boot the phone from external power ..
rather then the EROM starting phone from power from phone battery .. when EROM is gone bad .. !
charge your phone battery to max always in this cases
yeah EROM goes dead when flashing fails .. especially due to current flow changes into phone .. !
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
23-02-2008, 02:04 PM
#22 (permalink)
^^so will i be able to reflash it on my own or it requires special equipments ???
23-02-2008, 08:03 PM
#23 (permalink)
Wire muncher!
Most prolly you can get back your phone by using a service cable and trying to reflash the erom. I dunno about Nokia but SE as tools like XS++/se tool lite which allow recovering the phone to a certain extent even if the dumb service center guys say the phone is dead. But if gdfs ic corrupted, nothing can be done afaik. Search around, you may find some flashing tools for Nokia phones.
23-02-2008, 10:15 PM
#24 (permalink)
^^thx...will look for it
edit : there was a software called phoenix which could do something like this....will check out..
downloaded the service manual for my mobile...but nothing useful in that
23-02-2008, 11:09 PM
#26 (permalink)
Web developer
phoenix might help
24-02-2008, 10:28 AM
#27 (permalink)
messing around with phoenix at the moment....
@moshel.....that site asks $30 for shipping alone...sheeh
24-02-2008, 01:18 PM
#28 (permalink)
^^yeah i saw that.....so thats abt 34$ for the cable....too much...but i have heard from frnds that the care center fellows use special cables. probably they use such cables..
@edburg...can u pls provide me a link of the phoenix software.
24-02-2008, 05:18 PM
#29 (permalink)
Web developer
^^it would be illegal here to share phoenix links...
24-02-2008, 06:26 PM
#30 (permalink)
let the person who has the link PM the detail to the person who want and not share it in the open forum!
