Old 01-02-2008, 09:34 AM   #1 (permalink)
rahul_jaiswal31's Avatar
Default Is this possible?
Hi friends. I want to know that can i use GPRS on my pc with my nokia 2626? If yes then which soft should i use? I have data cable of my cell. Thanks in advance.
rahul_jaiswal31 is offline
Old 01-02-2008, 10:51 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: Is this possible?
I do not use any other applications to connect to the internet through my SE W700i, just use the default Windows Dial-up.
I think you can also use that but only if u know the correct settings for your service provider.
BTW which service provider do u use ?
debsuvra is offline
Old 01-02-2008, 02:25 PM   #3 (permalink)
Default Re: Is this possible?
i use the best idea. Note that my phone only supports the GPRS. It has no irda or bluetooth
