Old 26-01-2008, 07:58 PM   #1 (permalink)
BE THE FIRST OR LAST
srikanth.9849671439's Avatar
Default help
where can i download the converter 4 mobile?
srikanth.9849671439 is offline
Old 26-01-2008, 08:07 PM   #2 (permalink)
Still learning...
He28's Avatar
Default Re: help
What kind of converter are you looking for?
People laugh at me because I am different...,
I laugh at them because they all are the same...
This is... attitude!
He28 is offline
Old 27-01-2008, 09:36 AM   #3 (permalink)
Default Re: help
video converter.
Old 27-01-2008, 10:36 AM   #4 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: help
Just Google.
Btw why have you put your mobile number in your id? Its not really a smart thing to do you know.
krazzy is offline
Old 27-01-2008, 09:10 PM   #5 (permalink)
Still learning...
He28's Avatar
Default Re: help
You may check -- media-convert.com
Let me know if it helps.
Cheers...
He28 is offline
Old 27-01-2008, 09:19 PM   #6 (permalink)
AJJU
azzu's Avatar
Default Re: help
sorry but Srikanth anna u must specify which type of converter u need or for which mobile or which Type (eg-avi,divx etc..) these will be lot easier to answer.
ANY VIDEO COnverter is a freeware converter which converts lot of Formats to ur mobile Format
I love and Live to Design
azzu is online now
Old 28-01-2008, 09:46 AM   #7 (permalink)
Default Re: help
I would never forgot my Id with my number. thats why i put my phone number!
Old 28-01-2008, 02:22 PM   #8 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: help
^^ Then you should've added just the last 5 digits to your name. Why add the whole number?
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 28-01-2008, 03:53 PM   #9 (permalink)
Default Re: help
That time I did not think much about it.
