Old 23-01-2008, 10:10 AM   #1 (permalink)
mohitgiri's Avatar
Default Flash Lite 3 For N95 8gb
friends i want to download flash lite 3 in my n95 8gb. although it is avail in latest service pack(firmware version). but i m not intrested to download it coz of its 107 mb size. plz suggest me alternate
regds
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 23-01-2008, 10:17 AM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: Flash Lite 3 For N95 8gb
Get the latest firmware. Nothing like it man. Improves upon Demad Paging, adds complete youtube support.
Would be worth it even if you have to pay something for getting access to the internet connection for an hour or two so that you can update.
There is a Developer's Edition FL3 file out somewhere, but i recommend you update your firmware.
www.twitter.com/alsiladka
alsiladka is offline
Old 23-01-2008, 10:29 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
yeah man update the firmware.the latest firmware is a gr8 improvement over the prev versions and has lots of changes.if ur on broadband d/l the firmware wont even take 1hr.
but if u still want Flash Lite 3 then d/l it from Adobe.
hellgate is offline
Old 23-01-2008, 11:37 AM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
If you still dont want to update the firmware but only install FL3, download it from here - http://www.adobe.com/cfusion/entitle...abs_flashlite3
Old 23-01-2008, 05:44 PM   #5 (permalink)
tell me guys...i have a n95 8gb...
if i update my firmware, will all the data frm my phone memory and 'other memory(8gb drive internal) be deleted???
wen i backup my data using the nokia pc suite/../..it gives me an option of choosing between
backup only phone
backup phone and mem card
my other question is...that in the phones which have mem card its fine...bt here that my mem is internal only...will my 8gb mem be treated as phone mem only or it ll treat it as mem card memory??
magneticme200 is offline
Old 24-01-2008, 02:30 AM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
backup only phone
only contents of phone memory will be deleted when u upgrade ur firmware.
hellgate is offline
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Ace or K-lite vish786 Software Q&A 20 18-04-2007 02:27 PM
Lite-on DVD-ROM not reading NucleusKore Hardware Q&A 6 04-04-2007 12:42 AM
