Yes to the patching season has started !!!
Great number of patches for db2020 are up and ready for use. Few are still in development and porting stage
db2020 phones are k530 k550 k790 k800 k810 k770 w580 w610 w660 w880 w710 s500 etc !!
infra has discussed about all old phones.. these are the phones built on new platform
Its now possible to have Megabass on all of the above SE phones
This is the patching guide at
se-nse also at
my site.
GEt all patches from here !!!!!!
http://mobilefree.ru/newbb_plus/viewforum.php?forum=24
flashing .. and customization !!
You can change these for all phones
Acoustics
Camera Drivers
MainMenu Icons and Elements
Display drivers
And if its a Walkman phone then you can also
add Flash menu, Walkman player skins, visualizations for Walkman 2.
You can use Far Manger to customize your phone too !!
You can follow the customization guide at
se-nse or at
my site
With image extraction tools you can replace sys graphics with your own
it will create a patch .. and you just apply it using SEUS !!
You can post all your queries here !!!! i will help out !!!
Those are the tutorials !! they should help you out max !!
