Hi
I have made a
blacklist of Vodafone Karnataka numbers from which annoying automated advertising calls are made. To avoid getting calls from these numbers you must activate NDNC by calling customer care, but it takes 45 days to get activated. There have been instances of it taking longer
In the mean time you have to put up with the calls.
+919986129687
+918041737975
+919916139710
+919986127148
+919986113952
+919986183574
+919916139711
+919986139214
+919739901640
+919986126451
+919739901641
+919739901634
How to use this list?
Nokia 33xx series phones and some other phones have an option to assign a ringtone to a particular number/caller group. Use this feature to assgin "no tone" to the above numbers, and if you cannot find the "assign tone" menu item in your addressbook, simply open a existing unwanted tone or an (empty) tone in your composer and press the 0 key once. This will make an entry 4- This is a rest note and does not make any sound. Now save this ringtone as say, silence, and go to your phone book and assign this ringtone to the above numbers.
Nokia S60 phones:
Use a
free call filter and add the above numbers to the blacklist to reject the incoming call.
Another trick you can try: If your phone can play wav files or mp3 files as ringtones download and extract one of the files attached to your phone. Assign it to the above unwanted numbers. The files contain 10 seconds of silence generated with Audacity
Updates to the above list and suggestions are most welcome
