Re: Nokia 5700 Vs E51
E51 has better looks, better keypad, better build quality, wi-fi, higher RAM and internal memory and is slimmer. 5700 on the other hand has a slightly bigger display, stereo speakers, music keys and comes with better headset with remote. Overall if you'll be listening to music a lot on loudspeakers or headset go for 5700. If you need wi-fi and type a lot of messages then go for E51. Both have similar sound quality through headset, although 5700 comes with a better pair. Camera quality is same in both. As a smartphone, both are equally capable.
If sound quality and camera quality is important to you and you don't need smartphone features then it'll be better if you go for SE K790i.
