Old 19-12-2007, 07:06 PM   #1 (permalink)
expertno.1's Avatar
Lightbulb Store 325+ songs in 1 gb card in full quality .
Yep its true and is experimented by me
See the list of mobiles supported at the bottom of the tut .
Most mobile users store mp3 files in their mobiles for playing songs .
The songs are either in converted mp3 format (low quality) or above 128 kbps (good quality) .
But in 950 MB one can only store atmost 160-200 mp3 songs in good quality , say 128kbps .
But now dont be a mere mp3 songs listener coz mp3 is outdated now ! .
Do you know that your latest mobile comes with aac , mp4(also m4a) support ?
Allmost all models manufactured by Nokia from the year 2005 have the mp4/m4a support.
More than 150 different phone models support aacPlus as of mid 2006
Here we go : -
1. Get the trial of dbpoweramp music converter from www.dbpoweramp.com (dont worry trial will work forever for aac / mp4 formats conversion)
2. a ) Download the m4a release 7 codec for dbpoweramp here
http://www.dbpoweramp.com/codecs-new...-Codec-m4a.exe
b) Aac release 1
http://www.dbpoweramp.com/codecs-new...ac-encoder.exe
3. You will require the neroaac encoder to make dbpoweramp work .
here
ftp://ftp6.nero.com/tools/NeroDigitalAudio.zip
Now you have got all the tools......
Now.....
a. Install Dbpoweramp
b. Install the codecs of step 2--> a and b
c .Extract the contents of NeroDigitalAudio.zip to some folder
4. Goto start-dbpoweramp music converter-dbpoweramp batch converter...
5. select the files from the right hand side
6. click on convert on the top-left corner on the screen and this window will appear
click on locate encoder and browse the directory where you extracted the nerodigitalaac.zip in step 3.c
select the neroaacenc.exe and click open
7. Time to set the encoder option to he aac
8. Time to set the bitrate .....
According to the latest technology 64kbps he aac equals 128kbps mp3 because of its technology called SBR . (will not discuss it)
But in order to get maximum quality set the bitrate to 80 kbps
you can also set the bitrate to 64 as you wish .....but not below 64
9. Define the folder and click convert .
10. it will enocode above 10x and more for faster cpus
within 1.5 to 2 hrs you will be able to get all 300+ songs converted to the folder .
5 min song = 2.6mb approx
Now ,
Copy the files to your mobile card and start listening 80kbps he aac (quivalent to 160-192 kbps mp3) .
Now ......special for s60 phones.....
if ur default music manager takes long time to load the songs list.....use the freeware oggplay mmf software for s60 .....it nor only is SUPER fast but also plays ogg , wma and mp3 formats and organizes them too !
here http://symbianoggplay.sourceforge.net/
Rock your mobile with 44.1 khz , 16 bit stereo quality sound !
This is for Nokia Mobiles (especially series 60) , series 40 , Sony Ericsson , but can be applicable on other mobiles if other mobiles have the mp4/m4a format support and good library manager (so that it can handle 300+ songs without hanging)
All mobiles of N-series supported
Mobiles of s60 feature pack 2 (6630 6681 6680) supported
Mobiles such as 3310c , and all music phones supported
Most new Sony ericsson phones supported
i have added the samples
Note : -
use only these two players to play both the files
1. VLC media player 0.8.6 from www.videolan.org
2. Winamp 5.05 + versions
song clip - somewhere i belong (rapcore genre) linkin park
m4a file (80 kbps)
http://www.fileden.com/files/2007/12...i%20belong.m4a
mp3 file (128 kbps)
http://www.fileden.com/files/2007/12...e_i_belong.MP3
Listen Urself and tell me any difference u hear !!
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 19-12-2007, 07:51 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: Store 325+ songs in 1 gb card in full quality .
Dude nothing new in here! Even Nokia Music Transfer application does that, only trouble is it is very buggy and somehow does not convert most of my MP3s.
I use Easy CD-DA convertor and convert them to m4a. Each song about 2 mb in size. And Easy CD-DA is a lot easier than the application you choose. All you have to do is download and install it, no extra codecs or encoders, alls built in!
Plus, it also allows you to search the Amazon sites for Album Art and keeps them after conversion. After getting my files converted, i simply transfer them using Nokia's Music Manager to sort them into folders.
Even the album art shows up in N73's Music Player.
www.twitter.com/alsiladka
alsiladka is offline
Old 19-12-2007, 07:57 PM   #3 (permalink)
expertno.1's Avatar
Nokia Music Transfer doesn't encodes above 64 kbps
plus sony ericsson and other mobile users dont have Nokia PC suite so as a whole to cover all sets this is the software i selected .
and easy CD-DA ......i tried it and it has a hell slow encoding speed ......plus it has old he aac format
the one i posted is new nero aac august 2007 format (latest) and is better in quality than the apple's he aac encoder ,....so you will get 20% more quality in sound .
Thanks
Regards.....
Expertno.1
Old 19-12-2007, 11:58 PM   #4 (permalink)
Tech.Masti's Avatar
I think it will work with my 6085, will test. I know about mp4, but heard about m4a first time, btw thanks
Tech.Masti is offline
Old 20-12-2007, 12:14 AM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
Have been using m4a in my N73 since long. Why 64 kbps? Even 32 kbps doesn't seem to have any difference with the original MP3.
Nokia N86 8MP
Lucky_star is offline
Old 20-12-2007, 12:34 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Transcoding is EVIL. Only convert to AAC from original files. Transcoding reduces quality even if the bitrate is preserved.
There is nothing new here. You just gave us an example of music conversion.
MeGUI is also good for the same.
You can easily make Scripts to automate the same for a huge list of files to be batch converted, with the offitial Command line encoder from Nero(trust me, nero is the best. Its better than Apple or FAAC)
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 20-12-2007, 02:35 AM   #7 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Completely agree.... transcoding hampers intricate details of quality....!!!!
There is a major difference in using High-Efficiency (HE)-AAC and Low-complexity (LC)-AAC codecs/Modes for compression... compare the frequency response curves of uncompressed songs and those compressed by LC and HE modes respectively.... even 96 KBps LC-AAC songs possess similar FR curves to the original... but when using HE-AAC, the waveforms are altered... so even if u get a very low file size, (~ 1 MB for a 5 minute song), the quality is severely hampered... !!! I can almost feel the creepy distortions and flat washed-out sound quality of low-bitrate HE-AAC encoded songs. So I always prefer 96-128 KBps LC-AAC m4a or 96 KBps WMA if I want to acheive lower file sizes.... they preserve the quality of most songs to quite a good extent while providing u lower file sizes...
btw, did anyone notice that while hindi songs (with lesser degree of complex sounds) sound almost good even at very low 64 KBps and 56 KBps of AAC/WMA, if the song comprises of complex sound mixes (Linkin Park for e.g.), even at 128 KBps LC-AAC, they sound pathetic to me in terms of quality. I always have to use at least 160 KBps AAC/128 KBps WMA/192 KBps mp3 to make it sound better....
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
rockthegod is offline
Old 20-12-2007, 07:03 AM   #8 (permalink)
Sangeet Premi
2kewl's Avatar
Tried it, the quality didn;t impress me though.
2kewl is offline
Old 20-12-2007, 07:28 AM   #9 (permalink)
expertno.1's Avatar
Dude .... its not evil ....even the mp3 you get is transcoded from audio cd ......and transcoding mp3 to m4a (HE AAC) even to 64 kbps doesn't reduces a little of quality .
And yes nero aac is better thats why have used it in dbpoweramp ...read bhai above .
dude its HE AAC only !!
thats why have provided 80 kbps
if u wanna compare see this
http://www.codingtechnologies.com/pr...whitepaper.pdf
first read this ....... theres no difference in mp3 quality of 160 kbps and 80 kbps HE AAC .....not at all ...everything is preserved.......
Dont post on your own.....get the knowldege first !!
Dude ...its surely true that you haven't tried it or you converted low quality song to 80 kbps He AAc (m4a)
convert the original ones then you cant hear any difference in the quality of both the songs ......
its proved by coding technologies and the various scales like mushra and noise show it .
READ THE PDF ABOVE and clear Your lol doubts of quality .
Thanks
Regards.....
Expertno.1
Old 20-12-2007, 08:14 AM   #10 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Originally Posted by expertno.1
....even the mp3 you get is transcoded from audio cd...
lol "Transcoding is the direct digital-to-digital conversion from one (usually lossy) codec to another. It involves decoding/decompressing the original data to a raw intermediate format" ..... c.f. Wikipedia. A song is ripped or converted (ENCODED) from uncompressed format (PCM) available as audio CD tracks to compressed digital formats such as mp3/aac etc etc... so while transcoding from a lossy codec as the source, the quality further degrades or at best efficiency, remains the same as the source, BUT doesn't revert back to the original quality of the uncompressed music... If u have used a song encoded in a lossless format such as Lossless AAC as the source while transcoding, that results in optimum quality and conversion...
Before u jump on to conclusions, why don't u do a little experiment on your own ... the tools are some basic software available on the net. Ok, I will tell u a long story, if u r so inclined....
When I got my W850 in 2006 winter, I was searching for the best codec suitable for my phone which would produce optimum music quality at the best file size. Sony Ericsson mentioned that the bundled 1 GB MSPD card would hold a 1000 songs .... that translates to ~1 MB per song.. and SE specifically mentioned those songs to be encoded using AAC+ (HE-AAC) codec. I then went on a rampage to uncover every possible research on AAC+... while every one of them claimed that HE-AAC can preserve the audio quality. at 80 KBps (above 96 KBps the encoder I used automatically switched from HE-AAC mode to LC-AAC mode) LC-AAC (forced) sounded worse than HE-AAC encoding of the same song (Linkin Park - One Step Closer.... source: Uncompressed PCM ripped from Audio CD)and HE-AAC resulted in 10% lesser file size than LC-AAC at the same bitrate (forced). But they both sound inferior to a 96 KBps LC-AAC encoded song and the HE-AAC algorithm tends to falter/show no better results above 96 KBps... so why would I go for a 80 KBps worse sounding compression when it sounds way sweeter at 96 KBps with a minimal increase in size....
AAC+ is better than LC-AAC at bitrates lesser than 96 KBps but they both are inferior to 96 KBps LC-AAC. AAC+ uses parametric stereo (stereo downmixed to mono and then spatially regenerated and transformed by the decoder) and hence "approximates" the quality of the source at lower bitrates. Thus when u analyze an AAC+ compressed song in an editor like Audition, u can see only a single conjoined-channel instead of two separate with a heavily altered pattern of FR curves/Gain analysis.... Due to this downmixing and consequent "regeneration" procedure, even though the codec can manage to hold as much music "quality" as 160 KBps mp3 even while while having lesser "data", the altered pattern of the "data" will result in a more "flattened" hearing by many people (as the destroyed data is being sort-of "regenerated" and "approximated" by the decoder using advanced enhancement algorithms). Thus it all depends on the DECODER QUALITY and EFFICIENCY !!! As far as I can recollect, its very hard to distinguish when you are listening on a computer (good decoder + higher processing) except for the mild "flat" hearing .... but once the songs are on ur PMP, man u WILL notice the difference.... !!
No codec (specifically the lossy ones) can preserve the complete quality of the song because those algorithms are specifically tailored to remove those parts of the uncompressed songs (lossy-ness of the codec) , which human ears cannot distinguish between.. Can u distinguish between uncompressed song and lets say a 256 KBps mp3 conversion of the same ?? In that case u can compare them using audio editors like Audition ..... Give it a try..
Old 20-12-2007, 11:02 AM   #11 (permalink)
Dark Overlord !!!
rockthegod's Avatar
A Little late for me ... but here u go.... Spectrum freq. Analysis graphs for "Bally Sagoo - Aap Ki Nazron Ne Samjha (Remix)" ... But I don't have the Audio CD with me now though I have the 320 KBps mp3 at VHQ Fraunhoffer encoding.. so it should be very close to the source uncompressed one....
Graphs for 320 KBps mp3 source, 96 KBps transcoded LC-AAC (m4a), 80 KBps transcoded LC-AAC (m4a) and 80 KBps transcoded HE-AAC v2 (AAC+).... file sizes 12.1 MB, 3.8 MB, 3.2 MB and 2.6 MB respectively... notice the regeneration or original attempted by the AAC+ decoder resulting in a "continuous" spatial pattern (the flattened quality of HE-AAC)...
Single Channel freq. spectral distribution......Used Adobe Audition 3.0 and Adobe Photoshop CS3...
Old 20-12-2007, 12:41 PM   #12 (permalink)
clmlbx's Avatar
OK
IF I CONVERT MP3 320 KBPS TO M4A 320 KBPS .
SO IS THERE WILL BE ANY QUALITY LOSS
bcoz of size, it gets reduced so I would like to do it
Athlon II X4 635 @ 2.9Ghz   Gigabyte GA-MA785GMT-US2H   Kingston 2x2 Gb 1333Mhz DDR3   WDC 500Gb Green   Palit GTS 250 512mb   Tagan 500W   Samsung B2030   Lg DVD Writer
clmlbx is online now
Old 20-12-2007, 01:02 PM   #13 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by clmlbx
OK
How would that reduce the size? Both are same bitrate. So a wiser thing would be to convert MPe 320kbps to m4a 160kbps (say for e.g). Quality will be almost same but size would reduce. The best thing actually is to skip MP3 altogether and directly convert to m4a (aac in m4a container) from the lossless source at desired bitrate.
infra_red_dude is offline
Old 20-12-2007, 01:24 PM   #14 (permalink)
Dark Overlord !!!
rockthegod's Avatar
a 320 KBps song encoded in both AAC and MP3 should be very close (in ideal case, equal) to each other in size because the bitrate is the same (as infra red dude rightly pointed out). It is wiser to use 160 KBps AAC as its quality is nearly equal to that of 256 KBps encoded mp3 while being much less in size...
But the choice of codec is ultimately subjective... many audiophiles claim that AAC gives much better sound quality (sweeter sound) while others claim mp3 to do so.. I personally found out that some songs sound better in AAC, so i use 128 KBps for them while some others might sound sweeter in mp3 format (for me 192 KBps VBR is sufficient.. Linkin Park always sounds better in mp3).... even in some cases I have found 96 KBps WMA sounds better than the rest.. Its after all your own personal preferences.. use a good set of earphone/headphones and experiment with all kinds of viable compression modes and codecs on your PMP (not on your PC) and see what suits you best....
Old 20-12-2007, 01:55 PM   #15 (permalink)
expertno.1's Avatar
have already experimented and is experimetning from the year 2004 .
Dude do you know first LC-AAC stands for Low Complexity
Low Complexity (LC) - the simplest and most widely used and supported . and i am talking here about HE AAC
LC-aac has noway quality gain over HE-aac (HE = High Efficiency)
AND HE AAC v2 and HE AAC v1 are same above 64 kbps !!!!!
Please think what you are writing and experimenting....
one side you are writing LC aac worse at 96 kbps (switeched automatically from he aac to lc aac) and other you are writing that both sounding inferior to 96 kbps LC-aac .
final :-
dont talk about LC-AAC , its the worst of all , dont convert any of you song to LC-AAC
HE-AAC is by far the most enhanced codec invented till now !!
i bet 80 kbps HE-AAC superpasse 128 kbps mp3
update : -
Note : -
song - somewhere i belong (rapcore genre) linkin park
m4a file
mp3 file
and
HUMAN EAR IS THE FINAL JUDGE !
Thanks
Regards.....
Expertno.1
Old 20-12-2007, 02:19 PM   #16 (permalink)
Dark Overlord !!!
rockthegod's Avatar
and one more thing you donno abt bitrates...if u then why writing 96 KBps , kb in capital ?????
Dude, do u know how to read ?? : No offense, but I had started all this bickering and long posting with "Low Complexity" expansion of LC AAC from my first post in this thread.. check back and READ properly.... reagrding the KBPs.. its Kilo-bits-per-second... or as u wud say kbps.... .. how can a song be encoded in kilo "BYTES" per second... of all the information provided, u grab hold of the non-essential habitual typos and bring them up... really pathetic !!!!
Again, Read properly, I clearly mentioned.. I DIDN'T SWITH BETWEEN LC and HE.. the ENCODER program automatically did... I had to FORCE LC AAC at lower bitrates and HE at high.... as does dBPowerAmp you mentioned....
Here are some friendly suggestions:
1) First of all, get a better knowledge of the codecs.. u r experimenting frm 2004 and this is where u r at.... seems someone sucks at doing proper research and experimentation....
2) Second, READ and READ... I have mentioned strictly that HE-AAC algorithm provides superior audio quality over LC-AAC ONLY at LOWER bitrates.... the algorithm practically doesn't work at higher bitrates... The European Broadcasting Union was behind the initial MUSHRA scale tests... and those were used commercially by CT, but those were not so conclusive as other tests followed.
3) OK.... I am fed up of writing.... read WIKIPEDIA :
Scientific testing by the European Broadcasting Union has indicated that HE-AAC at 48 kb/s was ranked as "Excellent" quality using the MUSHRA scale. [1]. MP3 in the same testing received a score less than half that of HE-AAC and was ranked "Poor" using the MUSHRA scale. Data from this testing also indicated that some individuals confused 48 kb/s encoded material with an uncompressed original.
Other testing indicates that material decoded from 64 kb/s HE-AAC does not have similar audio quality to material decoded from MP3 at 128 kb/s[2]. However, this testing was conducted in an uncontrolled manner and cannot be deemed conclusive.
Further controlled testing by 3GPP during their revision 6 specification process indicates that HE-AAC and its derivative MPEG-4 HE-AAC v2 provide "Good" audio quality for music at low bit rates (e.g. 24 kb/s).
MPEG-2 and MPEG-4 AAC LC decoders without SBR support will decode the AAC LC part of the audio, resulting in audio output with ony half the sampling frequency, thereby reducing the audio bandwidth. No known tests have been conducted which compare the audio quality of such decoded material.
HE-AAC today competes only with Microsoft's low-bitrate WMA Professional codec.
4) AND visualize my SIMPLE graphs properly or do your experiments properly.... I am not gonna fight over this simple matter with someone clearly lacking advanced knowledge and who strongly holds to his wrong/partly right beliefs and doesn't bother to stand corrected... So u will hear no more from me.. I have provided enough data from my part, the intelligent readers can sort them out for themselves...
1) Why won't anyone talk about LC-AAC.. we have our fundamental rights.....
2) Are you ordering ppl not to use LC-AAC... ?? If u r gonna use low bitrates.... better to use HE-AAC.. if u r gonna use high, better to use LC-AAC...
3) theres other more advanced codecs out there and certainly they are used by transmission professionals.....
4) It is just a claim.. no unequivocal conclusions yet !!!!
Keep your encoded files to urself.. what do you think.. We don't have a PC or what ??
Old 20-12-2007, 02:32 PM   #17 (permalink)
expertno.1's Avatar
dude thats what am talking we have to get more and more songs at excellent quality then why one should convert for LC-AAC to 96 or more 128 why not mp3 ? if its high bitrate mp3 is good bhai !!
i think you should hear both the sounds i provided and clear your mind
thats what i wanna say for 64-80 kbps HE-AAC is far better than LC-AAC
lol.......for high bitrate i will always use MP3 !!
for low bitrate <80 kbps i prefer HE-AAC
it is already used in "AacPlus v2 by Codingtechnologies [8] is also standardized by ETSI (European Telecommunications Standards Institute) as TS 102005 for Satellite services to Handheld devices (DVB-SH) below 3 GHz."
we are here to discuss and resolve the detective stories .....not to run away from them
then correct it bhai coz you are typing it everywhere !!
and
(128 KBps) plus (128 kbps) = 144 kBps
Thanks
Regards.....
Expertno.1
Old 20-12-2007, 02:44 PM   #18 (permalink)
Dark Overlord !!!
rockthegod's Avatar
and thats the thing i am talking about from the beginning that HE-AAC at 48 kbps is excellent.......equivalent to 96 kbps mp3
so 80 kbps HE-AAC is equivalent to 128-160 kbps mp3
see in the MUSHRA scale urself !!
this all thread is about SBR technolgy so from where low complexity comes ?
Thanks
Regards.....
Expertno.1
The Mushra test results are not unequivocally accepted (read Wiki)... 128 KBps LC-AAC= 160-192 KBps mp3 in quality as is generally accepted...
80 KBps HE-AAC may pawn 128 KBps mp3 but not 192 KBps, so it doesn't go anywhere near 128 KBps LC-AAC (from earlier logic)...
I mention it again: If you are gonna use bitrates lower than 96 Kbps, use HE-AAC but if u r gonna use higher bitrates, better to use LC-AAC as HE-AAC doesn't work properly above 96 Kbps..
Old 20-12-2007, 02:47 PM   #19 (permalink)
expertno.1's Avatar
bhai read post #17 ......was editing for more and you posted quickly bhai
and we consider 128 kbps mp3 good quality.....
bhai : -
HE-AAC IS LIMITED TO THE BITRATE OF 128 kbps AND IS OF EXCELLENT QUALITY AT ITS MAX BITRATE i.e 128 kbps .
in simple one line ....upto 80 kbps use HE AAC bhai and get sound quality equivalent to 128-160 kbps mp3 for mobiles ....in this way many songs will be for mobile ......and since human ear is the final judge i say ma suggestions are not wrong
Thanks
Regards.....
Expertno.1
Old 20-12-2007, 02:52 PM   #20 (permalink)
Dark Overlord !!!
rockthegod's Avatar
the annoying thing is that u r mis-interpreting my writing.... I have compared 80 Kbps HE-AAC to 80 Kbps LC-AAC and both to 96 Kbps LC-AAC.... the order is:
96 Kbps LC >> 80 Kbps HE >> 80 Kbps LC....
For higher bitrates like 128 Kbps, why would I use mp3 when 128 Kbps LC-AAC provides similar quality to 160-192 Kbps mp3 at lower file size.... tell me this first.. !!!!
And why do you not get one thing... I MENTIONED IT EARLIER IN MY EARLIER POST.. LISTENING TO ALL THESE SONGS ON A PC WON'T DO A THING BECAUSE IT IS HARD TO DISTINGUISH BETWEEN ANY ENCODED FORMAT BECAUSE OF THE PC's SHEER PROCESSING POWER, ALL DECODERS PERFORM GOOD.... ITS THROUGH WAVEFORM ANALYSIS ONLY, THAT COMPARISONS CAN BE DONE ON A PC . Use ur PMP and then tell me which sounds good and which doesn't...
Old 20-12-2007, 02:58 PM   #21 (permalink)
expertno.1's Avatar
For higher bitrates like 128 Kbps, why would I use mp3 when 128 Kbps LC-AAC provides similar quality to 160-192 Kbps mp3.... tell me this first.. !!!!
dude we are here to discuss abt space conservation in mobiles.......not for pc playback of 192 + kbps quality......
1. all songs we get from cd's are mp3's of 128-160 kbps
or even higher
but why one should waste time to converte these all to LC-AAC above 128kbps?? , if mp3 is providing me excellent quality at its simple available original bitrate .....thats why dude ........i prefer MP3 at high bitrates ....no need to convert ....its readymade .....
Have already tested and played songs in N70 , 3110c , 5200 , 5700 and N73 ........even 64 kbps he aac stream sounded evryone (me , ma bro , ma friends and all respective mobile owners ) equal to 160 kbps mp3 !! in all phones above !!
Thanks
Regards.....
Expertno.1
Old 20-12-2007, 03:03 PM   #22 (permalink)
Dark Overlord !!!
rockthegod's Avatar
Thanks
Regards.....
Expertno.1
To be precise, we are here to discuss about space conservation with optimum quality... read my earlier post back as I have added a few things which u have definitely missed due to fast posting ... I am not talking about PC playback but playback on ur PMP and I have repeated this fact in every post...
wow. how this discussion changed its course .. phew... good nite.. its too late for me already... !!!!
Old 20-12-2007, 03:05 PM   #23 (permalink)
expertno.1's Avatar
plese refer post #21 again and.....
yes i have mentioned it in each and every post........
that for mobiles 80 kbps HE AAC is just enough to listen songs at optimuuuuumesssssssst quality .
and dude what are you trying to say ?
for your LC-AAC stuff.....----->
see this graph and tell me which encoding technique wins ?
didn't they all meet at 128 kbps ?
between 108 to 128 kbps all the three encoding techniques have same quality .....
isn't even 80 kbps he aac better than 96 kbps lc aac .....which contradicts your earlier posts this :- ---
one more thing , even AAC main is better in quality than the LC-AAC at 96 or 128 kbps .....
so dude correct urself by reading this
AAC Main - This is the deluxe model that includes all the tools available and delivers the highest quality audio.
AAC LC - LC means "low complexity." It reduces audio quality while also reducing processor demand.
AAC SSR - SSR means "Scalable Sampling Rate." It's the same as LC with a different filter bank and a special gain control.
Originally Posted by www.chiariglione.org/mpeg/
There are three profiles for the AAC standard, called Main Profile, Low Complexity Profile, and Scalable Sampling Rate Profile. The Main profile is intended for use when processing, and especially memory, are not at a premium. The Low Complexity profile is intended for use when cycles and memory use are constrained, and the SSR profile when a scalable decoder is required
Through rigorous testing of every imaginable way by The MPEG organization's tested the MPEG family of compression codecs and published the MPEG-2 AAC Stereo Verification Tests. If you just absolutely have to read this thrillride document, it's availabl e as a .zip file at www.mpeg.org/MPEG/aac.html
The study found this ranking of the best sounding codes:
1) AAC Main encoded at 128 kbps
2) AAC LC encoded at 128 kbps
3) AAC SSR encoded at 128 kbps
4) AAC Main encoded at 96 kbps
5) AAC LC encoded at 96 kbps
6) MP2 encoded at 192 kbps
7) And in 7th place the most popular format today! MP3 encoded at 128 kbps.
source : - www.angrycoffee.com
and www.chiariglione.org/mpeg/
i think i did a mistake of not posting it before
even i have posted this thread after a lot of experiments and results ......
have read many pdfs on AAC mp3 and all other codecs including this .......readu urself !!
http://people.arcada.fi/~johnny/MobileAudio7.pdf
http://www.ebu.ch/CMSimages/en/tec_d...tcm6-10497.pdf
Thanks
Regards.....
Expertno.1
Old 21-12-2007, 11:57 PM   #24 (permalink)
The Sexy Beast
for those who don't have ears of carnivores.here's how to do it easily
1.Use mp3gain and set the volume to 98-100db for every song(some songs which have volume about 90-92db might crack if there's heavy bass).so always first analyse them.
2.Use Xillisoft video converter to convert to .m4a.use 32kbps bitrate and 44100 frequency.The normal version allows for 5 min of transcoding per file.
the best part is that it's VBR so the bitrate is maintained according to the complexity in sound at that moment.
the result is 75-100kbps of LC-AAC.
3.Use Winamp to edit tags.
i've 523 songs in 1.3gb in my mem-card and quality is same to that of mp3's of anywhere between 128-320kbps and 96-192kbps WMA.
guyz why fight over whose's graph has more slope/area under the curve,etc.lol.it doesn't matter if your screen has a few dead pixels while watching a 1080p movie.
ratedrsuperstar is online now
Old 22-12-2007, 12:35 AM   #25 (permalink)
Toh Fir aao
@expert no1 U used a lot of time for this thread to compile but
buddy i dont think so that ur thread woth any appreciation coz
.... i agree AAC have better quality on lower bits
but only if played on desktop speakers....
In mobile less RMS speakers appr. all bitrates are same.... (if converted properly)
I can bet you in quality that i'll give you even less size MP3 file compared to ur AAC (whatever be the version) and quality is great even better than ur AAC (only in mobile speakers.......)
Method: Use mp3 cutter n joiner
in settings set minimium bit rate at 32 kbps MONO n quality 3
now goto Variable n set it to 64 n quality 2 (encoding MRAH)
click on FORCE minimum bitrate
n now get 1.9 mb file size for 5 min song n again i can bet u'll get
great sound with convetional everywhere used file type....
one more thing... i have near about 180 mp3 songs,,,
2 full 3 hours movies,, 28 avi songs,,
~30-40 softwares all converted by me on my 512 original mmc
http://gstek.info || http://xscams.com || http://thetelecomnews.com
Join us over Gstek to experience latest on technology, Telecom, downloads etc :)
hac_king is offline
Old 22-12-2007, 09:03 AM   #26 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Well.. I've tried LC-AAC, HE-AAC, HE-AACv2, Ogg AoTuV, all at 64 kbps. To me Ogg always sounds the best! Im not saying Ogg is better than AAC.. Just that probably my N70 does not support HE-AAC, as the file sounds right on PC, but it sounds muffled on the phone Probably the phone discards the SBR part of HE-AAC.
kalpik is offline
Old 22-12-2007, 09:19 AM   #27 (permalink)
The Sexy Beast
@hac_king - we're not talking of speakers they sound so lame on every phone.and if you keep audio in mono whats the use of listening music.do you have some mono phone?
Old 22-12-2007, 10:35 AM   #28 (permalink)
A LOTR fan
x3060's Avatar
i downloaded and heard the music in my k750 just now . . and i would not recommend it at the present quality . its full of bass . sounds too bad. i suggest you up the quality settings . .you made that song horrible to listen
i must add . . the mp3 that you gave along has richness in it . . but it sounds bad too - did you rip from cd?, i dont think so . . please provide a sample that you can rip from cd.
am on phone now . . edit the above -i need a sample that you ripped from cd. in both formats , thats all . with the current settings the mp3 is far rich.and the other is not
How many kilometers are there from washington Dc to Miami beach?????....;)
unban praka123!!!....
x3060 is offline
Old 22-12-2007, 01:05 PM   #29 (permalink)
The Researcher
Good tutorial, dude, Keep it up
Ramakrishnan is offline
Old 22-12-2007, 01:44 PM   #30 (permalink)
expertno.1's Avatar
Dude N70 doesn't decodes the HE-AAC part of .aac file
dude you have to convert it in .mp4 / .m4a ...then it will recognize and
decode the SBR part ...even it supports PS tooo./ N70 rocks !
@x3060 ....dude does k750 supports AAC+ ?
in gsm arena its given mp3/aac player not eaac/eaac+ player ......
if it doesn't supports eaac then there will be no quality in song bhai ! it will be full of bass .....no SBR !!
i had already mentioned in the first post that only the phone which have eaac support will work !
LOL !
i will give you a 24 bitrate .m4a file having Spectral Band Replication and Parametric Stereo ......even mp3 of 64kbps cant beat it in quality in MOBILE SPEAKERS ! .
take a N70 , N72 , N73 or 5700 from any of your friend and play 24 kbps .m4a file (SBR and PS technolgy encoded)
and play your mp3 ....i challenge you that the m4a will sound 100 times better than that !!
Note:- MP3pro has SBR technology but is not supported in mobiles
Thanks
Regards.....
Expertno.1
Better Quality on Tv tuner card on cable ssdivisiongermany1933 Hardware Q&A 3 19-11-2007 04:21 PM
iTunes Store Tops Three Billion Songs aryayush Technology News 3 01-08-2007 03:01 PM
Store Msgs on Memory Card mughal Mobiles and Tablets 9 11-03-2007 05:21 PM
Want to store messages in memory card or phone memory(Motorazr V3i) thetopcyborg Mobiles and Tablets 2 01-12-2006 01:45 PM
How to store mp3 songs in a mobile with good quality ? PraKs Mobiles and Tablets 10 23-07-2005 12:13 AM
