18-12-2007, 12:43 AM
In search of light...
Media player for SE W580i
just received this sms from cousin:
Look 4 a media player which plays al type of media files 4 my cel...
his phone is SE W580i. pls suggest a freeware.
http://abhijeetdeb.com
18-12-2007, 01:14 PM
Dark Overlord !!!
Re: Media player for SE W580i
Try KDPlayer .. nice Java based player.... I had it for my W850i... google and u may get a customised vesrion for ur W580i...
one link here customised for K800... LINK
C2Q6600@3.2G; eVGA nforce 780i; eVGA 8800 GT 512 MB (650/1900/1620) in SLi; 2 GB OCZ EPP DDR2 8500@1066M; PP&C Silencer 750W; Antec 900
AT&T Tilt WM 6.1 Pro Running Android
Sony PSP 2000 5.0-m33
18-12-2007, 01:29 PM
dude the default player is much better in w580i !
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
18-12-2007, 07:00 PM
^i know its good. but i want a player which can support multiple formats.
18-12-2007, 07:12 PM
Wire muncher!
Any player will only support the formats which are natively supported by the phone. You can't add new formats to the media player! This feature is only available in Symbian/Windows Mobile/Linux based phones. No firmware based phone will allow this.
19-12-2007, 08:02 AM
Techtree Reviewer
I just downloaded that. But its not a media player as it only plays music and not videos. Also it asks for my permission to do everything, like changing track, forwarding, changing skin, etc. Always asks whether it can read my memory. Also no equalisers. Built-in Walkman player is better, however it does not support Album Art like KD Player.
19-12-2007, 08:40 AM
Dark Overlord !!!
As far as I can remember, it plays videos too albeit not full screen... sorry, I dun hv my old W850 with me now otherwise wud hv told u the xact steps.... Regarding the matter of continuous askin, u have to set its preferences to "Never ask.." by using the application preferences.. Go to "Applications" menu, select KDPlayer, press the key for "More" and then set the "Permissions".. Allow it to "read user data" and "write user data" by setting those options to "Never Ask"....  it is still a development version I think, so u hafta follow the developmental threads on the net for newer versions.....
Ok.. on second thoughts lemme give it a try...this procedure is from my memory.. it may be wrong... go to Menu>Playlist>Add New Files. Browse the filesystem and add compatible mp4 video files.. and it will play them flawlessly (except for the full screen part)...
r u using a K series or an old W series phone?? ... Walkman 2.0 player supported album art !!!
19-12-2007, 03:38 PM
Techtree Reviewer
I don't have a never ask option in my phone. Either it always asks or doesn't allow permission at all. Also i don't have mp4 files on my phone right now, only 3gp which don't show up in the list and the app reports my video folder to be <empty> which it most certainly isn't. Anyways i have W710i which has Walkman v1.4 and doesn't support Album art.
20-12-2007, 02:47 AM
Dark Overlord !!!
I have never really tried so much on older W series phones, interesting point you mentioned about not availability of "never ask" on W700... I have a friend here who still has his W800, I hafta go & check it out !!!!
20-12-2007, 07:33 AM
Techtree Reviewer
Um... Its not W700i. I have a W710i.
20-12-2007, 09:42 AM
Dark Overlord !!!
srry  I misread it !!!!
20-12-2007, 01:18 PM
Wire muncher!
The option of Never Ask will only be available if the Java App was signed with a certificate which is installed in the phone.
20-12-2007, 01:32 PM
Dark Overlord !!!
Gr8... I hafta try this out !!!  Thanx for this useful piece of info.  But shouldn't all SE phones of similar models (W710, W810, W850 etc etc) have the same certificates installed?
20-12-2007, 01:46 PM
Wire muncher!
Goto Settings > Connectivity > Internet Settings > Security > Java Certificates. Check the installed certificates. If the third party apps are signed with one of these then you haf those extra Permission options. I believe there are options to install more certificates, thru wap. This is done for security purposes, otherwise if you give permission to some rouge program then it may cause havoc!
