The iPhone you will buy will already be unlocked and jailbroken and will come with Installer.app already in place. All you'll neeed to do to get a whole host of awesome third party native applications is click on Installer.app and download to your heart's pleasure. Everything is absolutely free.
Therefore, almost every single stupid reason Mr. gx_saurav so graciously mentioned becomes null and void.
Originally Posted by gx_saurav
You cannot change the ringtone
You can. For free and very easily.
You cannot install application
You can, of course, and the applications are far better and much more easy to install than Symbian or Windows Mobile applications. Best of all, they are all free.
You cannot install JAVA apps either
Who cares!
You cannot record videos
Not yet but this functionality is coming in a few days through third party applications.
You cannot forward an SMS
You can.
The video quality is awsome, provided u have time & patience to convert all your existing media into iPhone specefic format.
Which phone plays all your videos as is!
You cannot use it as a Removable drive, like u can use an iPod
Agreed. You cannot do that. Not yet, at least.
You cannot copy songs back to another computer once u copy it to iPhone
Yes, you cannot and probably never will.
You cannot use it for chatting, except if u want to rely on web based IM clients.
Ha! Ha! The iPhone has more native instant messaging clients for it than my Mac has.
All said and done, however, I still wouldn't recommend that you buy the iPhone because it isn't officially supported in India yet and if something breaks (the cases of iPhones having hardware defects have been few and far between though), there'll be no one around to fix it and it is just a tad too expensive to be used as a paperweight.
