Old 13-12-2007, 10:16 PM   #1 (permalink)
Default ipod song arranger
hey .. jst bought an ipod nano 4 gb .. i used the itunes software to sync my songs bt the thing is if i choose a folder with 20 songs (which may be from different albums) i get all the different folder names in the coverflow as well as in the albums section .
pls cn u guys suggest me an alternative to itunes which cn get me rid of this problem . ... n i did search the forum n even downloaded 2 softwares , bt none of them recognised the ipod .
krrrish is offline
Old 14-12-2007, 02:56 PM   #2 (permalink)
aryayush's Avatar
Default Re: ipod song arranger
iTunes is your only option. In the settings, disable the option that says "Copy files to iTunes Music folder when adding to library" and your problem should be taken care of.
aryayush is offline
Old 14-12-2007, 03:11 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
im not sure i understood what ur saying; ipod/itunes doesnt use folder names or file names
http://beingmanan.com
iMav is offline
Old 15-12-2007, 09:45 AM   #4 (permalink)
hullap's Avatar
see this http://www.yamipod.com/
hullap is offline
Old 15-12-2007, 10:08 AM   #5 (permalink)
Searching...
you can try SharePod. Here is it's download link:
http://www.sturm.net.nz/downloads/sharepod/sharepod.zip
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
How to convert a lower bitrate MP3 Song to a higher bit rate song? ajayritik Software Q&A 22 26-03-2008 11:57 AM
Is there any software which remove only song and not music of that song. mastterofminds Software Q&A 3 30-09-2007 06:53 PM
Get song lyrics while playing a song !!! mantoadmire QnA (read only) 4 02-08-2007 09:09 PM
personal arranger sites SE><IE QnA (read only) 1 15-04-2007 12:35 PM
Ipod - Quick Navigation to 'Now Playing' song... amitskale Audio 1 02-04-2007 04:26 PM
- by reddick
- by bhaskar
