Vodafone doesn't have any unlimited plan and that is plain pathetic. Period. Thats why i switched to IDEA and i am very happy with it. At my home i get speeds from 16-20 KBps in daytime and 18-25 KBps in night, offpeak hours. Ofcourse, these speeds only happen where EDGE is available otherwise its 5-8 KBps max. But fortunately, at my home, EDGE is available with full signals.
Originally Posted by wizaryan
how do i use the GPRS or EDGE on my HTC touch phone? i call up the vodaphone guyz and they say i cannot use the basic GPRS on my phone as its a windows based mobile and i need to pay them minimum of 200-300 bucks to use it....can some one help me please
just to mention i am located at Mumbai
I think you try this method and it will work coz i was using it before when i was on vodafone:
1. Goto Start>Settings>Connections. Click Connections. Goto Advance tab.
2. Just below the first dropdownlist are two buttons : Edit... and New... Choose New... (Please make sure you choose the buttons below first dropdown list and not the second one.
3.On the General Tab, Enter a name such as Vodafone GPRS Settings.
4. On the Modem tab, click New. Enter a name for example, GPRS. In the "Select a Modem" dropdown, select "Cellular Line(GPRS)". Click Next
5. In the Access Point Name enter portalnmms (case sensitive, in lowercase only).
6. On the next screen, just click finish.
7. Now back to the previous screen, you should have your new modem in the list, Proceed to Proxy Settings. Here tick the checkbox "This network connects to the internet" and "This network uses a proxy server to connect to the internet". Both should be checked.
8. In "Proxy Server" textbox, enter 10.10.1.100.
9. Now Click the Advance Button. The window that opens will have 4 settings in the listbox : HTTP, WAP, Secure WAP, and Socks
Click one by one on each of these and enter this info:
Server : 10.10.1.100
Port : 9201
rest all fields blank
Enter the same in every settings, ie. HTTP, WAP, Secure WAP and Socks.
10. When done, click OK twice to return to the Advance tab of Connections.
Now click Select Networks again and in the first list box select your newly created connection. In the second listbox select "My Work Connection".
11. Click OK and restart your device.
It may take a while after restarting for GPRS/EDGE to become active so try again and again in 5 miutes interval. It should be up and running in 5-10 minutes.
Try it and post back here in case of any problems as well as if you succeed in doing this so that everybody else get to know that this is a working solution
Enjoy!
