Old 11-12-2007, 07:49 PM   #1 (permalink)
Amatur Modder
Post GPRS Radio for n-gage?
Hi friends.
Activated gprs on my n-gage qd. Can I have radio through it? I installed virtual radio, but it says dns lookup failed.
niravjadwani is offline
Old 12-12-2007, 02:08 PM   #2 (permalink)
Default Re: GPRS Radio for n-gage?
try LCD Jukebox app, it has many radio presets. they have a 30 minute trial version, it it works tell me.
casual_gamer is offline
Old 12-12-2007, 02:12 PM   #3 (permalink)
Google Bot
Pathik's Avatar
LCG JUkebox
Spod Radio
Virgin Radio
Visual Radio
Dont remember if Mundu works.
Pathik is offline
Old 12-12-2007, 02:18 PM   #4 (permalink)
Are you using full GPRS or wap only GPRS? I have used the virtual radio app on my old ngage without problems in the past (Well.. the only problem I had was the buffer time which is incredibly slow and makes the radio-listening experience a tad irritating) I hope you have a really faaaast GPRS connection! As for the LCG Jukebox app, I am unsure if its available for the Ngage.
I'm busy now. Can I ignore you some other time?
Wh!Zk!D is offline
Old 12-12-2007, 02:36 PM   #5 (permalink)
Its available and i have it on my ngage. I can't test it coz hutch's gprs/wap plan's simply suck. From the past month, Lcg jukebox hangs after about 5 minutes of starting the app. so i'm not using this app these days. I had tested LCG earlier with spice wap, which provided a max speed of 12kbps(1.5KB/s). The radio would pause a lot due to slow speed. Overall the app worked.
Old 13-12-2007, 02:44 PM   #6 (permalink)
Amatur Modder
Its wap only connection. Will any of this would work?
Old 13-12-2007, 02:49 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Nah. Nothing.
Pathik is offline
Old 13-12-2007, 03:03 PM   #8 (permalink)
Cool G5's Avatar
You will need a GPRS connection,WAP won't do.
Cool G5 is offline
Old 13-12-2007, 04:26 PM   #9 (permalink)
did you guys tried with wap or are u just assuming that it won't work? coz Lcg jukebox online radio worked from my spice wap last year, though the speed was pathetic.
Old 13-12-2007, 06:47 PM   #10 (permalink)
expertno.1's Avatar
Originally Posted by niravjadwani
Hi friends.
Mundu is free and works on GPRS
radio.mundu.com
get your free app by registering
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 14-12-2007, 09:41 AM   #11 (permalink)
Amatur Modder
Hi expert..
Mundu is not supported on my phone. Series 60 not listed there..... And lcg jukebox also I don't think is supported...
Old 14-12-2007, 10:24 AM   #12 (permalink)
Cool G5's Avatar
Post Re: GPRS Radio for n-gage?
I have tried it on NOP.It didn't work.
Cool G5 is offline
Old 14-12-2007, 08:56 PM   #13 (permalink)
expertno.1's Avatar
Hi expert..
Dude thats sad i have used n-gage and i think it is symbian 6 or 7 .
so download the version 7 of symbian and tell ......
there are other java radio apps also like m f radio
http://www.mobango.com/media_details.../Rok9p67LzJc=/
try this and tell
Thanks
Regards.....
Expertno.1
Old 15-12-2007, 02:46 PM   #14 (permalink)
dattebayo
anispace's Avatar
ngage is series60 v6 so mundu wont work coz itz available for v7 and above only.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 15-12-2007, 07:57 PM   #15 (permalink)
expertno.1's Avatar
Yep but since it supports java use the MF radio (which i provided above) .
it will work as it has worked for java phones like 3110c and all (my experience) .
But MF radio required at least 40 kbps good connection dude.....
Thanks
Regards.....
Expertno.1
Old 15-12-2007, 09:20 PM   #16 (permalink)
Google Bot
Pathik's Avatar
not v6 but os6/6.1
Pathik is offline
Radio On PC(Not Internet Radio) mr_356 Internet & WWW 4 07-08-2007 04:53 PM
Online Radio for Airtel Gprs! digit i am thinking Broadband and DTH 10 01-07-2007 06:30 AM
N-Gage QD - Do they have modem for gprs Browsing ? steelwin Mobiles and Tablets 5 16-07-2006 02:48 PM
GPRS (General Packet Radio Service) a new BOON imported_joy QnA (read only) 17 27-05-2005 08:37 PM
- by reddick
- by bhaskar
