11-12-2007, 07:01 PM
Best Phone Around 8K?
Well guyz, help me out with your suggestions.........I have a budget of 8k and my only MUST HAVE requirement is that it can accept MMC or SD card mainly.I want a versatile Mp3 player probably even FM with it. Camara is not the biggest issue the issue is music.........Well thnx for any help fellas.
www.harivarrier.com
Check out to earn money...
11-12-2007, 07:26 PM
Techtree Reviewer
Re: Best Phone Around 8K?
There isn't any good phone left in the market which supports MMC and the only SD supporting phone in the market in ROKR E6, which is way beyond your budget. Looking at your requirements and budget, i'll recommend SE W700i.
Prasad Naik
Technology Reviewer for TechTree.com
11-12-2007, 07:27 PM
Google Bot
if mini sd ll do then get a 6233.
11-12-2007, 07:36 PM
well wat I meant by MMC or Sd card is I need some kind of extendable memory......... and btw if anyone can tell me the specific meamory card cost for 1GB,I will really appreciate it.
Thnx guys.
www.harivarrier.com
11-12-2007, 07:49 PM
Google Bot
Then u hav many options...
U ll get a 1gb micro/mini sd for 400 bucks..
U can get a 6233/k550i/3500c/w700i/w810i..
11-12-2007, 07:52 PM
hmm which is THE best? and probably the cost too? [Me in chennai btw]
and btw whats the battery life?
www.harivarrier.com
11-12-2007, 08:56 PM
AJJU
u asking about mobile ?
if yes go for w810i or w700i for no-nonsense music mobiles
I love and Live to Design
11-12-2007, 09:07 PM
^^ yeah ofcourse.
www.harivarrier.com
11-12-2007, 09:27 PM
Techtree Reviewer
I'll suggest you buy only original memory cards. I've had a bad experience with one fake M2 that i bought. It only lasted a couple of days after purchase before getting permanently corrupted.
Prasad Naik
11-12-2007, 09:31 PM
thnx krazy btw are these original costs???
www.harivarrier.com
12-12-2007, 06:14 AM
Techtree Reviewer
^ I don't think so.
12-12-2007, 10:49 AM
Wire muncher!
8k, SD, music? Sorry pal! Outta luck!!!! No brand there which will satisfy all these needs.
Nokia 6233 - average music and cam, supports microSD
SE W700i - better music than 6233, average cam, supports Memory stick pro duo
SE K750i - music: somewhat between 6233 and W700i, great cam, supports Memory stick pro duo
I wouldn't recommend buying N3500 so soon.
12-12-2007, 10:58 AM
I suggest SE K550i . u flash it to 'walkman' making it W610i+cybershot....
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
12-12-2007, 11:05 AM
Wire muncher!
SE K550i is available for over 8k. If he's ready to spend that much then fine
12-12-2007, 11:09 AM
ya,but he won't regret it ,it is worth for dat money
12-12-2007, 01:12 PM
may be Samsung E840
12-12-2007, 05:33 PM
Wat would you guys say abt Nokia 5300 ???
does look large but the display size is awesome .....does anyone use it?? and wat is its battery life with continuous usage?
www.harivarrier.com
12-12-2007, 06:13 PM
* Teh Flirt King *
Nokia 5300.... Used it for a month... it sux big time.... I wanted to buy this one but after testing it for a month I canceled it and bought N72.
Don't go for Nokia 5300.
If you are not so concerned about Brand you can check out some mobiles from Spice And Fly. They are cheap (in cost) but certainly not cheap quality.
12-12-2007, 06:30 PM
#19 (permalink)
thnx Quiz Master
Guess I will go for K550i then  [A cristmas offer might as well bring the price down a bit]
www.harivarrier.com
16-12-2007, 09:15 AM
#20 (permalink)
Guys is there any slow down for the phone if I add 2 GB card?
And is there any decrese ion the batter time if I patch the firmware with that of 610i???
Thnx for the help fellas
www.harivarrier.com
16-12-2007, 01:32 PM
#21 (permalink)
Wire muncher!
1) No
2) Don't think so. Wait for akshay to respond. He has a K550i flashed to W610i.
17-12-2007, 06:13 AM
#22 (permalink)
Anyone pls tell me if there is decrese in the battery time if I patch 610i onto k550i???
thnx for the help infra red
www.harivarrier.com
18-12-2007, 06:54 PM
#23 (permalink)
hey dude don't bother
if camrea is not the beggest issue then E250 is the right choice for you
it accept MicroSD card
i swear i did not belibe that but it is true
it has good Mp3 player and FM radio too
and it cost is not too much around 5000/-
you can go for samsung E840 also
it is also very good and very stylish phone
you can go here for getting complete details about this mobile phones
30-12-2007, 12:02 PM
#24 (permalink)
What is the price of samsung e840 ?
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
30-12-2007, 03:45 PM
#25 (permalink)
Guys I have bought the phone..I got k550i
www.harivarrier.com
30-12-2007, 04:58 PM
#26 (permalink)
Wire muncher!
^^^ Congrats
