| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Backup and Data Transfer You have to understand that you can only back up your data on the PC provided your phone has PC connectivity. It could be via USB, Bluetooth, Infrared or Wi-Fi if the device allows for it. But backing up your data is the best thing to do as soon as you get a new mobile. If you’re moving from an older version all you need do is copy your contacts on to your SIM card so you wont have to keep sending business cards or reenter all your contact information. Next off, connect your new phone up to your PC and do a quick backup with a PC Suite software that the company should provide. Nokia and Sony Ericsson have their own, or you could use third party software like Oxygen Phone Manager. These applications allow you to back up all your data, and this doesn’t just include your contact base and schedule but even your current settings, images, videos etc. Basically it takes care of everything that’s on your phone and memory card. Should your phone ever get lost or stolen and you need to recover the data, it’s all safely backed up on your PC. Since a lot of the new phones have a syncing option already in the phone it would be a good thing to just leave it on and simply let it update your PC with new information. If necessary you can also back up your SMS. In case you’re wondering where all of your data gets stored, try your Outlook or Outlook Express. All your contacts and schedules should show up there and it's easy to find and manage them. Incidentally, the software usually works in both directions. So if you update your PC, your phone will get updated as well. All you need to do when you get a new phone is simply sync it again with your PC and your data will miraculously reappear. Lock Codes There are a few way to protect your data in case your mobile does get stolen. Firstly you can have a Key Lock Code. That way every time your mobile goes into standby and you tap a key nothing will work till you key in the keypad code. Secondly, you can have a PIN activated. For mobile noobs, a PIN or Personal Identification Number is provided by your service provider for your SIM card protection. If that is activated and the phone is rebooted, you will need to type in the code to use that card. Lastly, you can also have a PUK (Personal Unblock Code), which is required if you enter the wrong PIN three times. If you don’t know the PUK, the SIM will get permanently blocked, preventing anyone from using your card. There’s also a phone lock feature which will lock just the phone and not the SIM card. This provides a way to render the phone useless, allowing you the feeling of satisfaction at outwitting a thief. Mobile Tracking Mobile Tracking can recover stolen or lost mobile phones. It operates in various ways. Firstly, like a car's Lojack GPS system a mobile could be located the same way using GPS satellites that should able to give you a more or less accurate reading as to where it is. Samsung uses another technique in some of its mobile phones, and BPL Mobile has incorporated it into SIM card services as well. How does it work? Let’s say a despicable character stole your mobile, threw away your precious SIM and you stupidly forgot to employ any locking mechanism. So what do you do? Nothing! Yup, that’s right. If the Mobile Tracker is activated, the phone will automatically send out an unregistered SMS to your mobile number from the new SIM inserted in the mobile and provide a location as well. BPL Mobile allows you to register two other cell numbers from your contact list to whom a message will be sent from the stolen mobile. The BPL solution is software-based; the software installed in the phone by the service provider will send out an similar unregistered message to the two predetermined numbers. Preventing Loss of Device and Data Here are some suggestions on how to prevent your mobile from being stolen, misplaced or just left behind:
Source:- http://www.tech2.com/india/topstuff/mobile-phones/lost-your-cell-no-worries/23305/0
!!!!*Little Knowledge Is Dangerous*!!!!! |
#2 (permalink) |
Pawned!... Beyond GODLIKE
wen i first read the headin i thought it abt gettin our lost phones back(n i started thinkin abt gettin all the phone me,myfather n my friends hav lost
If God has indeed created Himself in His own image, then I submit to you that God is a cockroach |
#4 (permalink) |
AJJU
^ But Guardian may simply do ur Work
Btw: Ya fun2sh i too was mislead by the Headin Old News but clearly stated for noobieprobie noobs
I love and Live to Design |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Vista worries cause businesses to consider Macs and Linux | CadCrazy | Technology News | 41 | 22-11-2007 04:54 PM |
| Microsoft Products worries. | shyamno | Software Q&A | 11 | 22-11-2007 04:04 AM |
| Digit Forum Post reply Worries | navjotjsingh | Internet & WWW | 5 | 28-07-2005 05:16 PM |
