Old 10-12-2007, 04:02 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Default how long does your Nokia N-series battery last??
i think these nokia N-Series batteries dont last long
they get discharged very soon. my new N-72 is crap....
i work in nite shifts ... keep the mobile charging till 3PM
then leave for work ...then next morning at arnd 6am when i leave for home it is almost discharged completely....
i make jus 3-4 five minute fone calls and keep the FM running for 2 hours ....
thats it .. this is pathetic ...wat say guys
and yea ... no applications are open ...
mekalodu
iinfi is offline
Old 10-12-2007, 01:55 PM   #2 (permalink)
Thumbs up Re: how long does your Nokia N-series battery last??
I have an N73 and contrary to the above post, mine works pretty well. It lasts a full day with my GPRS and applications on.. which according to me is acceptable as I always keep the screen maxed out at full brightness and I have this strange habit of keeping the bluetooth on as well. I guess the N72 has a lower mAH battery. I am happy with the N73 though.
I'm busy now. Can I ignore you some other time?
Wh!Zk!D is offline
Old 10-12-2007, 02:10 PM   #3 (permalink)
Cool G5's Avatar
Default Re: how long does your Nokia N-series battery last??
My friend has a N70ME,he uses his cell mostly for net browsing for some 5 hrs a day,calls for around an hour & BT sharing also.His battery lasts for a whole day or sometimes even a 2 days.
I think your battery is faulty.Check it with nokia priority.
Also don't overcharge,it ruins the battery life & charge holding capacity.
Cool G5 is offline
Old 10-12-2007, 04:07 PM   #4 (permalink)
respect mah authoritah!!
girish.g's Avatar
my dad's n80 lasts for 2-3 days with wifi on
girish.g is offline
Old 10-12-2007, 04:19 PM   #5 (permalink)
Sing Along Samsung
Tanmay Satpathy's Avatar
After the price cut of N72 some phones behaves in the same way. Is the price cut culprit ?
Tanmay Satpathy is offline
Old 10-12-2007, 05:04 PM   #6 (permalink)
I do not believe that a price cut might be the culprit.. might be an issue with a specific batch of batteries?? Just a thought..
Wh!Zk!D is offline
Old 10-12-2007, 05:55 PM   #7 (permalink)
AJJU
azzu's Avatar
dude u hav got a faulty BAttry thats it check it
I love and Live to Design
azzu is online now
Old 10-12-2007, 06:32 PM   #8 (permalink)
expertno.1's Avatar
Yep mine N70 battery ahs been ruined......its 1 year old and due to a lot of gprs work ....it remains in charge.........so it doesn't alsts long.......
will take a new one soon
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 10-12-2007, 07:07 PM   #9 (permalink)
Wandering in time...
Ankur Gupta's Avatar
My N73 battery lasts 3 days with minimal usage.
I can listen 8 hours of music in a single charge on loudspeaker.
Can use GPRS whole day on single charge.
So its pretty good.
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 10-12-2007, 07:19 PM   #10 (permalink)
AJJU
azzu's Avatar
^^same with my N70 me
azzu is online now
Old 10-12-2007, 08:31 PM   #11 (permalink)
^^Post edited to make the situation clearer
Old 10-12-2007, 09:14 PM   #12 (permalink)
assasin's Avatar
My N95 8GB battery lasts for 1.5 days with moderate usage of GPRS,music player,radio,WiFi and BT.it drains very quickly if i use GPS.
assasin is offline
Old 10-12-2007, 11:47 PM   #13 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
what!!!!!!!!!!!!!!!!!! My n80IE with wifi on and browsing is alive for 3.5 to max 4hrs
the.kaushik is offline
Old 11-12-2007, 12:55 AM   #14 (permalink)
assasin's Avatar
^^^ at TX pwr levels ru using ur N80.for better battery backup reduce the TX pwr level to 4mW
assasin is offline
Old 11-12-2007, 04:58 PM   #15 (permalink)
girish.g's Avatar
i dont actually browse i just have the option of scan for wifi network every 5 mins
girish.g is offline
Old 11-12-2007, 07:17 PM   #16 (permalink)
What is tx power
Old 11-12-2007, 07:34 PM   #17 (permalink)
SymbianGeek
FM is always gonna be a major power drainer.
Just do this once:
Charge up your device and use it without listening to FM at all.You would notice where all the power is going.
Also one more thing you can do is,drain you battery completely and then keep it for charging,it will take a bit longer to charge completely but will hold charge better.
A general tip(this one is left to your convenience):charge only when the battery bar hits the lowest.Keeping your device charging unnecessarily does not really help u r battery's life at all.
--eminemence.
Visit http://flaminghorns.com
eminemence is offline
Old 11-12-2007, 09:44 PM   #18 (permalink)
Cool G5's Avatar
Right.Unnecessary charging ruins the battery life nothing else.
Charge after complete draining.
Cool G5 is offline
Old 15-12-2007, 06:36 PM   #19 (permalink)
mekalodu
iinfi's Avatar
thanks for all your replies folks ...
sry i cud not get back earlier.
i found what the culprit is .... contrary to the note in the first post that no application remains open ...i found that everytime i make a call, selecting the contacts frm the contacts list ... the contacts folder remains open in the background .. which results in a battery drain ...
i doesnt happen always as i use my mobile frequently to call only 4-5 no.s and they are all in my speed dial
speed dial doesnt open the contacts folder .... so i dont notice the battery drain on a regular basis ... well trouble solved .
hope you understood what i said ...
mekalodu
iinfi is offline
Old 15-12-2007, 07:55 PM   #20 (permalink)
expertno.1's Avatar
Na dude....contacts will never drain your battery
untiland unless you have some heavy app running such as gprs app or other.....
i have a lot of experience in mobiles so take ma point .
simple contacts in background is just nothing to drain the battery.....
probably ur battery is faulty.....
Thanks
Regards.....
Expertno.1
Old 15-12-2007, 08:05 PM   #21 (permalink)
mekalodu
iinfi's Avatar
ohk ....
battery drains only when something is open .. so i thought thats the case . will chk with the service center ...
thanks
mekalodu
iinfi is offline
How long does Inverter Battery Last ? Hackattack Chit-Chat 3 02-03-2009 03:19 PM
Nokia Xpress Music Series Vs. SE Walkman Series just4fun Mobiles and Tablets 29 12-09-2007 10:50 PM
nokia n series vs sony ericsson w series... ssk_the_gr8 Mobiles and Tablets 23 11-09-2007 09:30 PM
