Old 09-12-2007, 11:48 AM   #1 (permalink)
rahul964's Avatar
Unhappy N72 Hangs
My nokia 72 hangs just after playing games i.e peterson cricket..
i scanned my phone through symantec mobile antivirus with latest update but there is noo virus.. why my phone hangs?????
rahul964 is offline
Old 10-12-2007, 03:54 PM   #2 (permalink)
respect mah authoritah!!
girish.g's Avatar
Default Re: N72 Hangs
are you using a memory card in your phone
girish.g is offline
Old 11-12-2007, 07:27 PM   #3 (permalink)
SymbianGeek
You can see such behavior if your main drive i.e. C: drive is filled a lot(must be left with 500Kb or less of space),so take time and free up your C drive and then you would face crashes less frequently.
--eminemence.
Visit http://flaminghorns.com
eminemence is offline
Old 27-12-2007, 08:52 AM   #4 (permalink)
rahul964's Avatar
yes i am using memory card 512mb in which 300mb are free, & with more than 8 mb free internal memory ..
rahul964 is offline
Old 27-12-2007, 09:45 AM   #5 (permalink)
AJJU
azzu's Avatar
Back up ur MMC Data .Format it and then restore it .
After that Backup ur mobile data I.E..Contacts.. mess,
soft format ur mobile and again restore
this is gonna surely help
I love and Live to Design
azzu is offline
Old 27-12-2007, 04:28 PM   #6 (permalink)
Check if ur cellphone needs a software upgrade http://www.nokia-asia.com/A4707378
enjoy is offline
Old 27-12-2007, 06:03 PM   #7 (permalink)
Boom Boom Boom
cooldudie3's Avatar
i think u should format ur phone card, then reinstall the games. The n72 isn't the best fone...
I'm back! Gimme a hugggggg...
cooldudie3 is offline
Old 27-12-2007, 07:20 PM   #8 (permalink)
dOm1naTOr's Avatar
It might also coz uve ended up using its ram...strictly speakin-not u but dat game...
Try dat game on some friends mobile...in same class.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
XP hangs ComputerUser Software Q&A 2 15-10-2007 05:55 PM
hangs a lot.....need help......... mayhemabhi Hardware Q&A 2 29-09-2007 03:38 PM
PC Hangs abhi99_iitg Hardware Q&A 5 30-06-2006 08:39 PM
Hdd hangs up cyrux Hardware Q&A 1 21-06-2006 12:30 PM
Xp Hangs dando Software Q&A 8 24-03-2005 08:32 PM
