Old 05-12-2007, 12:54 AM   #1 (permalink)
Unhappy Which 1 is best N72 or W700i or K550i???
Plss suggest me.... I have budget arnd 8k ...srched sum cell fones ..found N72, SE W700i and K550i acc to my budget... but not able to decide which 1 is best??? Please help me... I want good music and camera both.
Any suggestion for other fones arnd my budget 8k (but only of Nokia or Sony Ericsson) also welcome!!!
Thanks in advance!!
dipak15 is offline
Old 05-12-2007, 04:36 AM   #2 (permalink)
vasulic's Avatar
Default Re: Which 1 is best N72 or W700i or K550i???
for 2-3k more u can get n73
vasulic is offline
Old 05-12-2007, 06:21 AM   #3 (permalink)
shashank_re's Avatar
^^Hello boss N73 is 15k!
I would suggest you to check W810i its around 9k.Good cam and excellent music.
shashank_re is offline
Old 05-12-2007, 06:28 AM   #4 (permalink)
als2's Avatar
^^^ he is talking about normal edition not music edition
als2 is offline
Old 05-12-2007, 06:46 AM   #5 (permalink)
A LOTR fan
x3060's Avatar
i think w700i is really good
x3060 is offline
Old 05-12-2007, 09:53 AM   #6 (permalink)
Sangeet Premi
2kewl's Avatar
Stretch your budget by 1K and get the W810i!
2kewl is offline
Old 05-12-2007, 09:58 AM   #7 (permalink)
Tech.Masti's Avatar
If you need symbian then go for 5700 or n73, else W810i is also a good option
Tech.Masti is offline
Old 05-12-2007, 01:29 PM   #8 (permalink)
Techtree Reviewer
krazzy's Avatar
I find N72 to be better because i prefer smartphones. Camera and music is also decent in N72.
Prasad Naik
Technology Reviewer for TechTree.com
krazzy is offline
Old 05-12-2007, 01:35 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
What about 6233?
desiibond is offline
Old 05-12-2007, 05:33 PM   #10 (permalink)
AJJU
azzu's Avatar
w810i for music ....
I love and Live to Design
azzu is offline
Old 05-12-2007, 10:57 PM   #11 (permalink)
Buy Nokia 5700 mex it's ultimate
speedrider - The ultimate
speedrider_100 is offline
Old 05-12-2007, 11:00 PM   #12 (permalink)
Exclamation Re: Which 1 is best N72 or W700i or K550i???
sooo many options.,...nw confused more .... u guys given me sum more options...so a bit more confused ..but plss try to understand ..i am not able to extend ma budget by 1.5k or 2k more ...coz i already putted ma extended budget 8k ...only i am able to spend is 500-600 bucks more ...so plss help me guys acc to ma budget....
Also i found dat W810i is of 10.3k and W610i is of 10.7k ...so cant able to buy dese ..plss help n suggest me acc to ma budget with good cam n music..
Thanks in Advance!!
dipak15 is offline
Old 06-12-2007, 12:16 AM   #13 (permalink)
Still Shining!
Lucky_star's Avatar
W700i is outdated anyway. Its camera lacks autofocus.
K550i is better. Later you can mod its firmwire to w610i
Don't go for N72(if you don't want a smartphone).
Nokia N86 8MP
Lucky_star is offline
Old 06-12-2007, 12:38 AM   #14 (permalink)
Tech.Masti's Avatar
If you cant increase budget then n72 is ok if you wanna go for symbian, else Motorola L9 have all essential features and price 7.4k only
Old 06-12-2007, 01:43 AM   #15 (permalink)
hey...i got k550i on dis diwali for 8k (with bill).... n i seriously love dis phone ....heres a mini review :
Pros :
Looks awesome... n unique ... n just 15 mm thick
Really fast interface.... with no lag at all ...even taking pics frm the cam n saving them takes 1-2 sec at the max...
Cam is very gud atleast for me....n after playing a bit with the settings even night pics come alright....n the autofocus rocks.....nwdays i use it instead of a scanner ....
vid recording is ok ... resolutio is quite low but u can zoom them without much distortion
btw it has a twin led flash too...
70mb inbuilt memory + 128 mb card bundled (ya...its 128 not 64)
multitasking possible... u can play games n listen to music at the same time
Decent speakers n i m not a audiophile so even the bundled hpm 62 sounds good to me....u can get hpm -70 if u want wit the extra bucks
U can use he flash even as a torch... might cm useful.....
Battery life is also gr8... hav to charge once in 2-3 days with moderate use
U can flash it to w610i
Cons
The keypad is a bit diff so u might wanna try first...but i got used to them right frm day 1
A bit delicate n is a fingerprint magnet...so get a crystal case
i think dats it...
hpindia is offline
Old 06-12-2007, 09:10 AM   #16 (permalink)
thnx hpindia...but plss do tell me wat's d hpm?? watever u hve written really excited me ,,,i also wana gud music ..thnx anyway
Pros :
Cons
i think dats it...
plss tell me ...wat's d benefit of symbian?? is it better den sony fones?? ..n also plss tell me wats d sony cellfones den have?
Thanks Lucky... i also want gud music...do k550i have dat?? also wana know dat ....wats d smart fone nw?? is dey better den oders..are sony fones not a smartfone???
dipak15 is offline
Old 06-12-2007, 10:42 AM   #17 (permalink)
Sangeet Premi
2kewl's Avatar
Dipak, W700i has better music and K550i has a better cam. Choose between those two.
I'd suggest W700i, good vfm!
2kewl is offline
Old 06-12-2007, 11:27 AM   #18 (permalink)
Unhappy Re: Which 1 is best N72 or W700i or K550i???
But i wana both gud music n cam ..plsss help
dipak15 is offline
Old 06-12-2007, 12:07 PM   #19 (permalink)
Albicelestes
Baker's Avatar
hi man...
i thing k750i..
will suits for u.....
it has good camera and music also good....
otherwise go for w700i
DREAM IT DO IT. DON'T let others steal your dreams.
Baker is offline
Old 06-12-2007, 12:29 PM   #20 (permalink)
do k550i dont hve gud music?? or do W700i dont hve gud cam?? plss reply
Originally Posted by deepak_cucek
hi man...
i thing k750i..
dipak15 is offline
Old 06-12-2007, 12:51 PM   #21 (permalink)
New
New's Avatar
+1 to k750i... Great camera and music...
New is offline
Old 06-12-2007, 05:00 PM   #22 (permalink)
Question Re: Which 1 is best N72 or W700i or K550i???
plsss guysss suggest me which cellfone shud i finally buy acc to ma budget(8k)?????
dipak15 is offline
Old 06-12-2007, 05:46 PM   #23 (permalink)
Albicelestes
Baker's Avatar
go for k750i....
it is a combination of both cam and music....
w700i is also has good cam but 750 is far better....
yesterday only my friend buy 750i...
it really rocks....
Baker is offline
Old 06-12-2007, 10:44 PM   #24 (permalink)
Y i am suggesting k550i over k750i is coz :
k750i is a really old model nw..... doesnt looks much good n k550i is slimmer
K550i has A2DP , EDGE , Fast Proccy , newer interface
The diff in their cams isnt much...n as i hav said k550i's cam rocks....
Dunno abt the music quality of k750i ...so cant comment
The default headset u get is hpm -62....it lacks bass n music quality....
U can buy the inear Hpm - 70(it has a 3.5 mm jack) costing arnd 800 buck if u want a better musical experience.....
So choose nw ... as per the features u want...
hpindia is offline
Old 06-12-2007, 11:48 PM   #25 (permalink)
Do they gimme d SE walkman's headfone?? r dey compatible or fitted in k550i jack?? ...where can i hve d oder headfone wid 70hpm?? ..
isn't i get dat 70hpm headfone within 500 bucks??? ..
dipak15 is offline
Old 07-12-2007, 08:27 PM   #26 (permalink)
respect mah authoritah!!
girish.g's Avatar
you wont get walkman headphone with k550
i bought hpm 70 in year headphone for rs 500 you can use any other headphone in its 3.5mm jack
girish.g is offline
Old 07-12-2007, 09:01 PM   #27 (permalink)
sumwat now i decided to buy nokia 6233(no music edtion) or k550i...plsss suggest me plssss which 1 is best ...n which 1 to buy and y??
also tell me wats d diff b/w nokia 6233 normal & music edition...only memory card xtra naa?? or sumthin else too???
dipak15 is offline
Old 07-12-2007, 09:30 PM   #28 (permalink)
The Thunderer
bhutanesedude's Avatar
I suggest u too go with Nokia of any model...its best
bhutanesedude is offline
K750i or k550i??????? ionicsachin Mobiles and Tablets 36 05-10-2008 11:49 AM
k550i prob ??? a_k_s_h_a_y Mobiles and Tablets 13 27-05-2008 09:55 AM
k550i queries....!!! hpindia Mobiles and Tablets 4 12-11-2007 01:14 AM
k550i work without sim? dany3112 Mobiles and Tablets 9 10-10-2007 01:34 PM
Mobile Apps for w700i W700i, i.e. java based blackleopard92 Mobiles and Tablets 1 05-09-2006 07:36 PM
