Old 05-12-2007, 01:21 AM   #1 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
Default Microphone mute
Whenever i restart my computer the setting 4 microphone normally turns 2 mute .How 2 solve this.
JohnephSi is offline
Old 05-12-2007, 10:02 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Microphone mute
are you using internal TV tuner card.
ravi_9793 is offline
Old 05-12-2007, 03:41 PM   #3 (permalink)
JohnephSi's Avatar
No
Old 06-12-2007, 05:04 PM   #4 (permalink)
troubleshooter
bluepearl's Avatar
does the mic work after that?
bluepearl is offline
Old 07-12-2007, 04:13 PM   #5 (permalink)
JohnephSi's Avatar
Yah it wrks after dat.
Old 08-12-2007, 03:00 PM   #6 (permalink)
troubleshooter
bluepearl's Avatar
goto recording control settings from
Run -> sndvol32
check which devices have been selected
select only microphone
also check advanced settings
If this doesnt work try updating your sound card drivers
Hav u installed any new media player or rec. s/w?
My volume settings also get changed when I use Media Player Classic
Mute Volume Thru Single Key-Stroke ddpatel78 QnA (read only) 3 23-07-2007 08:50 PM
Mute Xp CA50 Software Q&A 26 27-06-2007 10:21 PM
Mute XP SP2 CA50 Hardware Q&A 2 08-06-2007 12:27 PM
HELP! MY PC HAS TURNED MUTE! mandar5 QnA (read only) 5 20-02-2006 03:14 PM
- by reddick
- by bhaskar
