Old 02-12-2007, 12:27 PM   #1 (permalink)
vasulic's Avatar
Default uninstall quickoffice
Hi all. I have install QuickOffice v4 demo downloaded from an unknown website. After the trial peroid. They ask me to buy the software. which i cannot do. Now I can't even view excel files. Any idea how to roll back to the free version? or uninstall? I tried removing it from file manager but of no use
vasulic is offline
Old 02-12-2007, 10:47 PM   #2 (permalink)
expertno.1's Avatar
Default Re: uninstall quickoffice
dont create two thread bro..........
and
go to system/apps/ and delete the office folder
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 03-12-2007, 05:35 AM   #3 (permalink)
vasulic's Avatar
Hi expertno ,read my theared again, i have tried it but could not remove
vasulic is offline
Old 03-12-2007, 09:46 AM   #4 (permalink)
expertno.1's Avatar
why ?
is it not listed in the app manager too ?
check ur pm , i have given u the software link
download it , install and then post , its v4
Thanks
Regards.....
Expertno.1
Old 03-12-2007, 11:41 AM   #5 (permalink)
Google Bot
Pathik's Avatar
Wich fone?? More Details..
Pathik is offline
Old 03-12-2007, 11:43 AM   #6 (permalink)
vasulic's Avatar
Nokia N73.
vasulic is offline
Old 03-12-2007, 12:33 PM   #7 (permalink)
expertno.1's Avatar
what happned bro.....is it working ?
just install the .sisx file afetr extraction of the part files i geiven u
if not worked then
two ways :-
backup data and format ur cell to revert back changes
OR
get this app
here
and follow this
here
now tell does it works ?
Thanks
Regards.....
Expertno.1
How can i uninstall.......? qadirahmed QnA (read only) 2 01-09-2007 12:02 AM
Cannot uninstall Suhas M Software Q&A 5 13-11-2006 07:49 AM
help please in uninstall shivi4 Open Source 3 27-07-2005 06:52 PM
Help me to uninstall ELX! kingraja Open Source 4 01-02-2005 06:10 PM
- by reddick
- by bhaskar
