I recently purchased a sony k550i ,and purchased a 1 GB memory card ,along with it .The combination worked well for 25 days.
However yesterday ,after my sister clicked some photos ,i decided to transfer it to blue tooth ,as i went to my bluetooth menu and reached till themes menu , suddenly the screen got white and the mobile automatically switched off .When i restarted it gave a message that " do you want to format the memory card " .I ignored it but i found that at every possible place (Camera,file system etc) it showed that memory stick is not available . When i connected it with my PC via USB the phone memory worked well but the memory card gave a format error .However i was unable to format the card as no format(fat16,32 etc) was possible.I formated it in my phone at startup promt but it showed unaviliable in usable areas and problem persist.
To check whether the phone has malfunctioned ,i inserted the 128 memory card which came bundled with it ,and it worked well .
What should i do ? I purchased the card for 1k and it has a sony brand marked behind it so i can't say whether it is duplicate or not.
