Old 15-11-2007, 01:31 PM   #1 (permalink)
mad1231moody's Avatar
Default Help me select
Hey guyz I am planning to buy a phone within 5~5.5 K range. I have a made a few selections. ell me which one should I opt
The first one is Fly sx300. Techincal Specs
The second is Sagem 550x. Technical Specs
The third is Samsung e250. Technical specs
The fourth is Sagem 411x. Technical specs
Now after looking the technical specs you would have found out that I am looking for an all capable mobile at cheap price. So please suggest
mad1231moody is offline
Old 15-11-2007, 03:27 PM   #2 (permalink)
Techtree Reviewer
krazzy's Avatar
Default Re: Help me select
Nokia 3110 Classic.
krazzy is offline
Old 15-11-2007, 03:31 PM   #3 (permalink)
Think Zen.
ray|raven's Avatar
If you can extend your budget to 6k,
go for SE w300i or Samsung SLIK.
http://www.gsmarena.com/sony_ericsson_w300-1486.php
http://www.gsmarena.com/samsung_j600-1970.php
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 15-11-2007, 03:32 PM   #4 (permalink)
Google Bot
Pathik's Avatar
If u can etend ur budget to 6k Get a 3500c
Pathik is offline
Old 15-11-2007, 04:26 PM   #5 (permalink)
AJJU
azzu's Avatar
^^ +1
I love and Live to Design
azzu is offline
Old 15-11-2007, 08:51 PM   #6 (permalink)
Hey u all recommending other phones, thanks for it. But the cell phones that I have selected are not up to the mark or what. And all the options that you all gave have all the features, need to check out.
please select the file girishrn Software Q&A 4 17-10-2007 02:08 AM
Help me select my next upgrade moshel Hardware Q&A 7 08-09-2007 11:21 PM
help me to select mobo n cpu lokeshv Hardware Q&A 7 05-09-2007 11:20 PM
Pls help me to select a smartphone !!! sainit Mobiles and Tablets 21 08-04-2007 02:17 AM
Help me select a GAME!!! neonet2004 Gamerz 5 13-08-2004 05:53 PM
- by bhaskar
- by soumya
