If ever u guyz dreamed of a cellphone crammed with features, drop dead luks, ground breakin design n wot nots.....wot wud it be like?!!?
herez mine...n a lot practical too...its possible!
formfactor undecided, slider or just touch screen oriented keypad....
3" VGA 16million display (Samsung inspired)
6MP autofocus Canon lens cam, 3x optical zoom, HD Video recording,
10GB flash,
256MB RAM
WiFi/WiMax
Easy 2 use joystick,
sd/mmc card slot,
SE shortcut/events key,
aluminum body, <14mm in thickness,
usb 2.0 port,
3.5mm jack,
play/pause ff n bw keys just below de screen ( like W960)
n all de usual goodies
still deciding on the Operating System/Interface.
Well, sounds silly..but dats like a babyz looney tune which helps me go to sleep...
wanna share ur wierd thots? den Plunge...!!
