Old 08-11-2007, 01:26 AM   #1 (permalink)
expertno.1's Avatar
Default AAC Streaming
Which Software will allow me to hear AAC streams like http://209.9.229.212:80
in ma N70 ?
Thanks
Regards.....
Expertno.1
expertno.1 is offline
Old 08-11-2007, 08:11 PM   #2 (permalink)
r2d2's Avatar
Default Re: AAC Streaming
Have u tried this
http://www.thobee.com/?page=2&pa=1&pb=0
(Not Free, according to website mp3, ogg, aac, aac+ streams are supported)
http://opensource.nokia.com/projects...lientPage.html
(Free, aac+ streams are not supported on N70)
http://radio.mundu.com/
(Free, Not sure if aac streams are supported)
r2d2 is offline
Old 09-11-2007, 09:48 AM   #3 (permalink)
expertno.1's Avatar
Originally Posted by r2d2
Have u tried this
na i have mundu , it doesn't supports aac streams
the first one i have tried but its trial version doesn't allows me to use aac ones.....if anyone can tell me that the first software really supports aac+ streams...then i will buy it.....
Thanks
Regards.....
Expertno.1
Old 09-11-2007, 06:47 PM   #4 (permalink)
r2d2's Avatar
I am a bit confused about the nokia internet radio because n70 has Series60 2nd ed feature pack3 which does support eaac and eaac+ and multimedia media framework (sort of plugin like architecture so other apps can make use of the codecs), so maybe they only mean s60 2nd ed fp2, better try it out and see.
r2d2 is offline
Old 22-12-2007, 11:23 PM   #5 (permalink)
expertno.1's Avatar
long time.....no see.....
so anyone has got any app ? or has tested thobee for eaac+ streaming ? .....help is required.......
Thanks
Regards.....
Expertno.1
Old 23-12-2007, 09:15 AM   #6 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Tried CorePlayer?
kalpik is offline
Old 23-12-2007, 09:18 AM   #7 (permalink)
expertno.1's Avatar
Originally Posted by kalpik
Tried CorePlayer?
dude why are you telling tried ?
it doesn't decodes HE-AAC v1 /v2 part of the .aac .m4a .mp4 file.......
it plays at 22050 khz which should be 44100 hz .
any other softie would be good to advice...thanks for reply though..
Thanks
Regards.....
Expertno.1
Old 23-12-2007, 09:27 AM   #8 (permalink)
kalpik's Avatar
Dunno then! What player do you use that shows you 44100?
kalpik is offline
Old 23-12-2007, 09:33 AM   #9 (permalink)
expertno.1's Avatar
Oggplay mmf for playing .m4a files (he-aac v1/v2)
Power MP3 for playing .aac files (he-aac v1/v2)
both show 44.1 khz and the quality is awesome.....
Thanks
Regards.....
Expertno.1
MP3 streaming software ra_sriniketan Software Q&A 6 12-12-2006 06:03 PM
Streaming Media iwant2breakfree QnA (read only) 2 06-04-2006 12:46 PM
How to rip streaming videos frm net? karthik55859 Software Q&A 3 16-02-2006 05:36 PM
Streaming Music on the LAN izzikio_rage Networking 4 11-11-2005 03:51 PM
- by bhaskar
- by soumya
