Old 03-11-2007, 12:26 AM   #1 (permalink)
anilmail17's Avatar
Default Data cable??
i have nokia 2626. there is a mini USB like port near the charging socket. Can anyone tell me which datacable i can use to transfer data between phone n PC. thnx in advance
visit my blog
www.anilsoni.wordpress.com:)
anilmail17 is offline
Old 03-11-2007, 01:20 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Data cable??
Official Nokia site says that it's not supported by them to connect 2626 with PC (check the user manual). However you can buy a DKU-2 Data Cable to connect 2626 with PC.
After purchasing the Cable, check this site,http://shoaib786.110mb.com/Nokia2626/Nokia%202626.htm it will be helpful with ur 2626.
debsuvra is offline
Old 03-11-2007, 07:01 AM   #3 (permalink)
Dude....... Mine is motorola l6i so which one for me.......?
I have my digi cam data cable is very simple to connect both the usb
i mean cam and pc..... and i use this for my l6i......?
qadirahmed is offline
Old 03-11-2007, 04:50 PM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
You will need Mobile PhoneTools® PC220. You can buy it from Motorola shop, it has a driver cdrom and the needed cord to connect to pc.
"Use the Mobile PhoneTools® software to communicate, sync and keep yourself organised. When connected via the included USB cable, your phone becomes your modem so you can surf the Internet, send & receive messages or emails, and stay up to date by synchronising your calendar and phonebook. With Mobile PhoneTools®, your Motorola phone and PC can also share your picture and other media files and you can create your own content, ringtones and screensavers. Multimedia: Exchange images and audio with your PC and create your own ringtones, screensavers and MMS."
debsuvra is offline
Old 04-11-2007, 11:04 PM   #5 (permalink)
But Dude how about the above question.....?
Old 06-11-2007, 01:51 AM   #6 (permalink)
anilmail17's Avatar
DKU-2 cable do not have a similar male connector for that socket. Can u tell me more about the data cable?? from the screenshot i can see that there is way we can connect the phone PC but which data cable is to be used?? plz tell me
hey i have found that the phone support the FBUS protocol n i know FBUS protocol very well. I can design my own data cable, if one can suggest me where can i find a spare male pin for that socket or if some already know the name of data cable which is easily available in market then plz tell me. I need the data cable despirately. Thnx in advance
visit my blog
Old 06-11-2007, 10:48 AM   #7 (permalink)
Back in Power
almighty's Avatar
any digi cam usb cable can be used
ˇuʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ˇʎǝɥ
almighty is offline
LG RD 2530 Data cable HELP!! max_demon Mobiles and Tablets 3 19-12-2006 12:07 AM
Lg data cable dodo QnA (read only) 1 14-06-2005 04:10 PM
Rworld on PC via data cable mohanty1942 QnA (read only) 6 06-03-2005 04:40 PM
- by bhaskar
- by soumya
