Old 29-10-2007, 04:22 PM   #1 (permalink)
Chetan1991's Avatar
Arrow Want a basic mobile and connection for net connection
Guys, I want to buy a basic mobile for interet connection, as I am fed up with slow dial up.Please reply soon.
Chetan1991 is offline
Old 29-10-2007, 05:25 PM   #2 (permalink)
caje143's Avatar
Smile Re: Want a basic mobile and connection for net connection
Just get a Mobile which supports GPRS, and which has IR/Bluetooth Support, or even USB Cable can do.. thats it..
Then you call the Service Provider.. i.e. Either Airtel/Idea/Hutch/BSNL or whichever.. and ask them for the GPRS Settings for your Mobile depending on which Service Provider you are Subscribed to..
Thats it.
COMPLAINING......
is good for you as long as you're not
COMPLAINING...... to the person you're
COMPLAINING...... about.
caje143 is offline
Old 30-10-2007, 09:42 PM   #3 (permalink)
Chetan1991's Avatar
Default Re: Want a basic mobile and connection for net connection
Thanx! Can you also suggest me some connection plan or which connection should I choose?
Old 30-10-2007, 09:47 PM   #4 (permalink)
Cool G5's Avatar
Airtel Mobile Office - Rs.15/Day.
Cool G5 is offline
Old 31-10-2007, 11:00 AM   #5 (permalink)
AJJU
azzu's Avatar
^^ go for Airtel its 15 per Day Ul
and also buy a good Mob with Edge and which hav good network reception probably SE (coz nokia get's hot usin GPRS ) and
connect it Via data cable Ir and blue tooth r much slow
I love and Live to Design
azzu is offline
Old 31-10-2007, 11:13 AM   #6 (permalink)
Cool G5's Avatar
^What???
My nokia never gets Hot when using GPRS.
Also Nokia is the best when it comes to network reception.
Cool G5 is offline
Airtel Internet connection via Mobile Abhishek Dwivedi Mobiles and Tablets 23 30-10-2007 07:52 PM
How to speed up your mobile net connection ? windchimes Mobiles and Tablets 2 12-08-2007 12:37 AM
Needed a mobile for net connection for 8k windchimes Mobiles and Tablets 7 01-08-2007 03:24 PM
how to use PC Internet connection on mobile? Rockstar11 Mobiles and Tablets 5 09-06-2007 11:26 AM
need a new mobile connection ashnik Buying Advice 1 15-02-2006 03:17 PM
- by bhaskar
- by soumya
