Old 28-10-2007, 05:44 PM   #1 (permalink)
Eager to learn.
power_8383's Avatar
Default N73 ME Firmware Update
Hi guys, while I was trying to update my N73 ME I've faced this problem.
It is saying that I'm using the latest version i.e. Version 4.0727.2.2.1 but I know that there is a new firmware available i.e. Version 4.0736.3.2.1.
No reply ?
Some things Man was never meant to know.
For everything else, there's Google.
power_8383 is offline
Old 28-10-2007, 09:05 PM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: N73 ME Firmware Update
I think you will need to change your product code to update to the latest firmware.A short tutorial for this is located here.
The product code you will need is 0537289 [Euro 1]
Life is as complicated as you say it is.
shady_inc is offline
Old 29-10-2007, 07:12 AM   #3 (permalink)
Eager to learn.
power_8383's Avatar
R u sure it will not affect my phone to bad condition ?
Old 29-10-2007, 11:10 AM   #4 (permalink)
AJJU
azzu's Avatar
^ Nopee
I love and Live to Design
azzu is offline
Old 29-10-2007, 09:50 PM   #5 (permalink)
shady_inc's Avatar
Not if you do everything properly.Just keep a note of previous product code in case something doesn't turn out well so you can reset it back using the same procedure.
Old 29-10-2007, 11:35 PM   #6 (permalink)
Eager to learn.
power_8383's Avatar
I'll try & let u know brother.
Old 31-10-2007, 06:55 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
The original product code is there on the sticker under the battery, You can get it from there later when you want.
www.twitter.com/alsiladka
alsiladka is offline
Nokia E50 Firmware Update - v7.36.0.0 alsiladka Mobiles and Tablets 4 18-10-2007 06:45 PM
Update Firmware topramen115 Hardware Q&A 1 24-08-2007 11:04 PM
cannot update firmware gau_pppu Hardware Q&A 17 17-01-2007 12:51 AM
Is Any Firmware Update Available For 7610 ? clmlbx Mobiles and Tablets 4 15-09-2006 07:52 AM
