Old 27-10-2007, 10:41 AM   #1 (permalink)
vasulic's Avatar
Default SKYPE and nokia 73
Can i use skype in my n73? anyone using?
vasulic is offline
Old 27-10-2007, 11:06 AM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: SKYPE and nokia 73
no not at all..what internet connection will you use?? If you have n80 or n95 you can as they have wifi... and for internet call lots of other softwares are there for free but all for these mobiles.. Eg: gizmocall etc
the.kaushik is offline
Old 27-10-2007, 09:14 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Yup u can (i think) if u hav igprs..
Pathik is offline
Old 03-11-2007, 11:45 PM   #4 (permalink)
N73 is symbian based and you can install software on it.
using gprs connection you can connect to skype server and make calls.
but in india the speed you will get in gprs is not suitable for clear voice calls.
better go for some wifi handset and using wifi and skype you can make calls.
lilovirus is offline
Old 04-11-2007, 02:22 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
You shall atleast need 3G or WiFi. the combination of N73 and Skype does not make sense in India.
www.twitter.com/alsiladka
alsiladka is offline
Skype or MSN harmads QnA (read only) 8 17-02-2007 03:41 AM
Skype thunderbird.117 QnA (read only) 1 13-09-2005 09:23 PM
SKYPE -- How to use? //siddhartha// QnA (read only) 3 23-02-2005 03:28 PM
