Old 25-10-2007, 03:05 PM   #1 (permalink)
New
New's Avatar
Default Help to set up Mobile Office
Hi digitians..
Please tell me the procedure to use internet on my pc by using 3110 classic phone as a modem(i have air tel connection)..
Please give me step by step procedure..
New is offline
Old 25-10-2007, 03:22 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Help to set up Mobile Office
does that phone have internal modem?
Gigacore is offline
Old 25-10-2007, 03:30 PM   #3 (permalink)
New
New's Avatar
yaa.. Please gigacore..
New is offline
Old 25-10-2007, 03:36 PM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
have you are installed the phone in your computer? i mean the data cable drivers and nokia pc quite?
Gigacore is offline
Old 25-10-2007, 09:17 PM   #5 (permalink)
New
New's Avatar
Let me say what i have done first
i connected my new 3110 classic(after saving the settings which i got from air tel) to pc through USB and installed pc suite on my system.After that i went to the option called connect to internet in pc suite.. I finished all steps in that connect to internet options.
What to do next?
Is drivers are required to usb cables which i used to connect my cell?(comp is detecting my cell and i can transfer data between cell and pc easily).
Is there any need of extra settings in internet options????
Please help me..
My airtel one weekly plan has already activated
Thanks gigacore....I managed to enable connection...Im replaying using Mobile Office only..
Thanks...
New is offline
Old 25-10-2007, 09:34 PM   #6 (permalink)
Back in Power
almighty's Avatar
U are using a local data cable
thats why ur modem is not geting detected...
use ur pc suite which u get with data cable
or can try new nokia pc suite...
but local made data cable gives lotz of trouble....
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 25-10-2007, 10:17 PM   #7 (permalink)
AFAIK 3110c does not come with a usb cable. Install PC Suite. check if your phone is connected to the pc suite. then goto connect to the internet, then settings/chose your phone/ select your network operator (airtel India) then cllick on finish.
if your phone have different modes of connecting to your pc then select pc suite and not data storage or printing mode.
Experience Is not Counted in Years.. But in the Countless Effort
www.kolasib.com www.zoram.org
valtea is offline
help needed to connect samsung x620 mobile to pc through airtel mobile office pmharsh Mobiles and Tablets 1 29-12-2007 04:07 PM
Airtel Mobile Office+without mobile the.kaushik Mobiles and Tablets 11 16-10-2007 09:45 AM
Mobile office help????(urgent)!!!! magnet Mobiles and Tablets 4 20-08-2007 11:59 AM
Mms Thru Airtel Mobile Office cerebral_stroke Mobiles and Tablets 7 21-01-2007 09:13 PM
Mobile Office on k750i mandar5 Mobiles and Tablets 4 11-09-2006 09:38 PM
- by bhaskar
- by soumya
