Old 23-10-2007, 06:20 PM   #1 (permalink)
ajayritik's Avatar
Default Is it ok to wind the Earphone wire ?
I use an earphone to listen to my ipod! Most of the times I wind the earphone wire around the iPod. My friend was telling its not advisable to wind the earphone as it will reduce its quality.. Is it true? What is the solution for this problem? Does this really effect in the long run? My earphone gets entangled if I dont wind it up!
ajayritik is online now
Old 23-10-2007, 06:28 PM   #2 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
Default Re: Is it ok to wind the Earphone wire ?
yes , winding is not recommended not because it reduce quality , but this may lead to permanent failure of the earphone
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 23-10-2007, 06:33 PM   #3 (permalink)
The wire may get damaged/break if you wind the earphone cable.
ThinkFree is offline
Old 23-10-2007, 11:37 PM   #4 (permalink)
himtuna's Avatar
No reduction in quality.
Man you can yourself hear no difference in winding and unwinding.
( The wires are not carrying high Voltage that will hinder the music signals)
Only care on you part is to handle it well.
http://www.himtuna.com/
http://www.himanshuthakur.com/
Do good to be good !
himtuna is offline
Old 24-10-2007, 12:20 AM   #5 (permalink)
The Devil's Advocate
iMav's Avatar
the only reason to avoid winding the wire is that it causes un-necessary stress on the wire .... fold them loosely no harm as in let the wir coil itself dont wind it around ur hand or something
http://beingmanan.com
iMav is offline
Old 24-10-2007, 07:33 AM   #6 (permalink)
Dreamweaver
Gigacore's Avatar
instead of winding it, you can fold in spiral manner and you can use the rubber tag to tag it
Gigacore is offline
Old 24-10-2007, 08:50 AM   #7 (permalink)
The Frozen Nova
casanova's Avatar
Winding is not recommended, however; I haven't faced any problem.
You can try putting Fevi-Kwick at the ends namely the plugin point and the ear pieces.
This wont cause any problems as it would avoid stretching of connections when you wind the earphones
www.nerdweed.blogspot.com
casanova is offline
Old 24-10-2007, 10:46 AM   #8 (permalink)
Cool G5's Avatar
Other than damage of tear, i don't think there is any harm in winding.
I prefer you keep it in a case or your sling bag etc.
Cool G5 is offline
Old 24-10-2007, 01:27 PM   #9 (permalink)
TheSaint
NucleusKore's Avatar
Earphone wires are usually very thin and delicate. Although they are malleable and ductile, even that has its limits
NucleusKore is offline
Old 24-10-2007, 03:59 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@ajayritik ...... winding = breaking of wire after some days\months ....... inturn lessening ur earphones life ...... coz cant b repaired .......
... W H O T ...
ax3 is offline
Convert a normal lan wire to Crossed wire{Urgent Help Required Plsssss} racevthme Tutorials 1 14-02-2007 03:27 PM
NASA World Wind 1.3.3.1 rajat22 Software Q&A 3 11-11-2005 01:51 PM
NASA world wind zegulas Software Q&A 2 26-05-2005 11:59 PM
World Wind Problem bharathbala2003 Software Q&A 11 06-03-2005 01:34 AM
- by bhaskar
- by soumya
