Old 18-10-2007, 06:55 PM   #1 (permalink)
AJJU
azzu's Avatar
Angry N70 No Screen :((
hey guys iam out station for few days but today suddenly my N70 screen is displaying correctly.It hasnt fallen or pressed.The screen is showing small pixels of colour(which we face on t.v while the cable is gone) .
i showed it to local mobile shop it they told its no problem with the Display
i showed it to NOKIa care they r telling something software problem
tell wat's really the problem my phone is not under warranty
help me guys iam out of station help iam desprate
I love and Live to Design
azzu is offline
Old 18-10-2007, 06:58 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: N70 No Screen :((
If its a software problem (wich i dont think it is. ) format ur fone to solve it..
i think its definitely a hardware problem.. get the display changed..
Pathik is offline
Old 18-10-2007, 07:09 PM   #3 (permalink)
AJJU
azzu's Avatar
man but the Nokia care people say's its no problem with the display
display is working fine
azzu is offline
Old 18-10-2007, 08:27 PM   #4 (permalink)
Wandering in time...
Ankur Gupta's Avatar
Peculiar problem...
Cant think any better than what pathiks said...
Nokia guys know better...
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 18-10-2007, 09:04 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
Seems like dead pixels. Show it to one of the 3rd party repairers.
If you want to check whether it is a software problem or not, reflash your phone using Nokia Software Updater.
www.twitter.com/alsiladka
alsiladka is offline
Old 19-10-2007, 06:24 PM   #6 (permalink)
AJJU
azzu's Avatar
^^ will try it
but any other idea's ????
guy's please help me
bump
azzu is offline
Old 04-11-2007, 03:07 PM   #7 (permalink)
wid million core procesor
davinci's Avatar
i hav faced da same prob with my n70. it is i think dead pixel. my display became normal automatically after 4-5 days. i hav faced it twice and everytime after4-5 days it became ok. so sitback and wait 4 a bit
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
davinci is offline
Old 06-11-2007, 08:27 AM   #8 (permalink)
I am having problem with my N72 display. 4 months old phone. for the last 3 days, display has started jumping and flickering at only the bottom. specially after standby. gets ok after some time. formatted my phone. can anybody tell something? help
bikrom is offline
Old 06-11-2007, 09:00 AM   #9 (permalink)
TheSaint
NucleusKore's Avatar
The Blank Screen of Death. It is possible I guess, have a similar problem on my 7610. Remove any memory hog apps you might have installed.
NucleusKore is offline
Old 06-11-2007, 04:30 PM   #10 (permalink)
AJJU
azzu's Avatar
my Problem still not Solved
azzu is offline
Old 06-11-2007, 05:27 PM   #11 (permalink)
!FREEWARES!
Akshay's Avatar
@azzu
If under warranty, tell nokia guys to repair it whatever may be the cause - hardware or software. Generally cos hav a disclaimer about few dead pixels which are generally acceptable.
I dont see how a software can cause dead pixels on your screen??? If it was a s/w. prb, formatting/flashing should have solved the prob.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 06-11-2007, 08:58 PM   #12 (permalink)
AJJU
azzu's Avatar
its not under the warranty that's the problem
ok but soon ill send it to HYd let's see weather the poblem get's solved or not
azzu is offline
my screen resolution problem causes blank screen with error malav11 Software Q&A 1 17-08-2007 10:54 AM
Blank screen medigit Software Q&A 2 21-11-2005 11:25 AM
welcome screen of xp Software Q&A 9 31-07-2005 11:25 PM
without welcome screen in xp gary4gar QnA (read only) 4 21-07-2005 05:38 PM
- by bhaskar
- by soumya
