Old 14-10-2007, 11:05 PM   #1 (permalink)
Default how do i read documents or text on my phone?
how do i add a text document which is 10 mb on my cell?as i need to do a presentation tomorrow.i dont think so i can add it in my message section?
can i save it as a draft i dont think so as they have a number limit.
viruses is offline
Old 14-10-2007, 11:10 PM   #2 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Default Re: how do i read documents or text on my phone?
which mobile.. if its n-series then off course u can do!
Buddy its the wrong section to ask for mobile query!
the.kaushik is offline
Old 14-10-2007, 11:14 PM   #3 (permalink)
sorry.it is 3230.cant i download documents into it from wordpad.
viruses is offline
Old 14-10-2007, 11:22 PM   #4 (permalink)
Sorry bro.. Not able to understand what is ur problem.. Do u want to read the doc or u just want to store it... if u want to store it use a mmc reader to write to your mmc or if u dont have a mmc reader and have a bluetooth then first change your message memory to memory card(By default it will be phone memory) and then send through bluetooth..
Old 14-10-2007, 11:24 PM   #5 (permalink)
yes i have bluetooth.i mean can i transfer wordpad document to my phone will it recognise the format.will i be able to view it on my cell bro....
viruses is offline
Old 14-10-2007, 11:28 PM   #6 (permalink)
It should if u have any doc reader or send as text file and u can read as normal text message...try once with a small file.. i don have the phone to try!
Old 14-10-2007, 11:52 PM   #7 (permalink)
thanks a lot pal.u r very helpful
viruses is offline
Old 15-10-2007, 12:03 AM   #8 (permalink)
Noobie Pro
alsiladka's Avatar
Have you installed any office suite on the phone? Get yourself a trial from http://www.mobisystems.com/ . It will be able to open Word, Excel and PP files. Since 10MB is a bit too much, i suggest you divide the document into 5 6 parts and save it on your MMC card and open them as and when you need them.
www.twitter.com/alsiladka
alsiladka is offline
Old 15-10-2007, 06:08 AM   #9 (permalink)
jatt's Avatar
office suite is better or install notpad software and otherwise there is adobe reader also presendt to read in the pdf format google for it go to funplusfun.com or google for these
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 15-10-2007, 12:26 PM   #10 (permalink)
thanks a lot people.kaushik and others this is the best and most helpful forum.
i had to install a document reader which i did and i can view text now.
thanks again
viruses is offline
iPhone can read Word, Excel, PDF documents aryayush Technology News 7 23-06-2007 10:53 PM
Unix text to notepad readable text? How? adithyagenius QnA (read only) 4 09-06-2007 07:27 PM
Free Office Word Plug-in for Read/Writing of OpenOffice Documents anandk Software Q&A 1 24-02-2007 04:50 PM
Image in text | bordered text goobimama Tutorials 5 03-02-2007 09:36 PM
Buyin Bluetooth Dongle For Nokia Phone ? Read This First din QnA (read only) 10 15-10-2005 07:40 AM
- by bhaskar
- by soumya
