Old 14-10-2007, 08:46 PM   #1 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Question Airtel Mobile Office+without mobile
Is there any option to do net using the Airtel Mobile office without using the mobile..Some type of sim reader! If its available what is it called and where shall i get and what will be its price?????
the.kaushik is offline
Old 14-10-2007, 08:58 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Airtel Mobile Office+without mobile
bro SIM Readers wont have inbuilt modem, so it wont work.
Gigacore is offline
Old 14-10-2007, 10:18 PM   #3 (permalink)
So is there no other option?
Old 14-10-2007, 10:22 PM   #4 (permalink)
Dreamweaver
Gigacore's Avatar
literally no other options. . . than buying a good edge enabled phone
Gigacore is offline
Old 14-10-2007, 11:00 PM   #5 (permalink)
Am using n80i.. but the problem is after say 6-7hrs of use the battery starts heating.. And i fear that the battery will soon get damaged!
Old 15-10-2007, 10:38 AM   #6 (permalink)
i thnk SE W series is better for this purpose coz their batteries are more reliable
navisangha is offline
Old 15-10-2007, 11:16 AM   #7 (permalink)
but i wont go for se w series leaving my n80i
Old 15-10-2007, 04:18 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
there is no other option ......
bt if u would just stop after 6hrs & let it cool & then after sometime use it .... though a bad advise .........
else if u wanna use 4 laptop use reliance or tata indicom ...... reliance just works 4 me ........
... W H O T ...
ax3 is offline
Old 15-10-2007, 09:42 PM   #9 (permalink)
They are too costly yar compare to airtel mobile office
Old 15-10-2007, 10:05 PM   #10 (permalink)
Google Bot
Pathik's Avatar
i dont think the battery ll get damaged.. most nokia batterie tend to get hot after extensive usage..
Pathik is offline
Old 15-10-2007, 10:15 PM   #11 (permalink)
No Problem with the batery man
i use my nokia N91 8Gb on internet 24x7,,,,,,,,,,,,,,,it use to heat up but no prob......
Whiskey Di Botal Vargi Main Ikk Kuri Fasa laye.............................
Ferozepuria is offline
Old 16-10-2007, 09:45 AM   #12 (permalink)
But how long have u used! I am getting problem(I feel the backup time has decreased) after 2 months of extensive use in internet!
help needed to connect samsung x620 mobile to pc through airtel mobile office pmharsh Mobiles and Tablets 1 29-12-2007 04:07 PM
<< Airtel Mobile Office Help!! >>> panacea_amc Mobiles and Tablets 6 17-04-2007 05:14 PM
Mms Thru Airtel Mobile Office cerebral_stroke Mobiles and Tablets 7 21-01-2007 09:13 PM
free mobile office on airtel SHEHUL Mobiles and Tablets 3 03-12-2006 11:36 PM
Help Needed For Airtel Mobile Office mandar5 Mobiles and Tablets 7 18-09-2006 01:33 AM
- by bhaskar
- by soumya
