Old 11-10-2007, 12:28 PM   #1 (permalink)
Default uploading songs to Nokia N95
so when i upload music files to my phone with the NOkia PC Suite, it now just upload the files to the phone memory and not the memory card. How do i change the setting so it will upload the files to the memory card?
An Jing is offline
Old 11-10-2007, 01:45 PM   #2 (permalink)
Noobie Pro
alsiladka's Avatar
Default Re: uploading songs to Nokia N95
Are you using Nokia Music Manager or Windows Media Player?
You have a variety of options for transferring your songs.
If you are using NMM, from the Options you can choose the drive and directory where the songs can be saved.
If you are using WMP and the phone in Media Player mode, i guess it transfers songs to the memory card itself.
If you are using Nokia Phone Broswer, then make sure you are pasting your songs in the Memory card.
www.twitter.com/alsiladka
alsiladka is offline
Old 11-10-2007, 03:05 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Use Nokia Fone browser and copy th files in memory card...
or just plug it in as a usb mass storage device nd paste..
Pathik is offline
Old 11-10-2007, 10:10 PM   #4 (permalink)
im using nokia music manager which convert the files to make it smaller and it goes straight to the memory card but now it goes to phone memeory. Today i try dragging the files to the memory card using the usb connecting to the phone and it works fine but i find using the NMM a better.
I click on options on NMM but theres no option to which directory where i can save it.
An Jing is offline
Old 12-10-2007, 12:40 AM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
Connect the phone and then open the NMM. In the options, there is the option to choose where the songs are saved.
Old 12-10-2007, 02:54 AM   #6 (permalink)
i try that but i don't see any options.
here's a pic i took for reference:
An Jing is offline
Old 12-10-2007, 08:36 AM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
Uhmm My Bad. Open settings. In the settings, you have that option.
Old 12-10-2007, 09:52 AM   #8 (permalink)
ok, i finally got it. Thanks alot alsiladka
An Jing is offline
Help: How to activate the preloaded songs in Nokia N73 ME akajain Mobiles and Tablets 3 26-06-2007 10:53 PM
how to unlock Nokia N73 Music Edition 100 preloaded songs ? Rockstar11 Mobiles and Tablets 7 10-03-2007 06:37 PM
download from Uploading ! ! ! ax3 Internet & WWW 2 03-10-2006 12:49 PM
Nokia to launch phone that stores 3,000 songs Sourabh Mobiles and Tablets 36 26-07-2005 11:07 AM
Am I Uploading???????? NonGeek QnA (read only) 3 21-04-2005 06:25 PM
