Old 02-10-2007, 07:45 AM   #1 (permalink)
Exclamation How to upgrade the firmware of my k310i with a .fbn file?
I wanted to upgrade the firmware of my phone. I downloaded the firmware. It is in .fbn format. I wanted to know which software will i require to use that firmware so that i can upgrade my phone.
Thanks.
sushantvirdi is offline
Old 02-10-2007, 03:51 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: How to upgrade the firmware of my k310i with a .fbn file?
you can use XS++ or SETools. but plz make sure people haf successfully flashed before jumping into the flashing bandwagon! backup first. if you find even a single failure case then back out, get to the root of the problem, rectify and only then attempt flashing.
infra_red_dude is offline
Old 02-10-2007, 05:47 PM   #3 (permalink)
Thanks for replying mate...
I wanted to tell you that i downloaded this flash from this link and the file name was K310_R4EA031_FS_INDIA_RED49.rar It has a .fbn file in it. I wanted to know whether i need only this file to flash or i have to download a .mbn file also? Also please clarify these two type of files and give me some instructions on flashing. Thanks very verytmuch.
Old 02-10-2007, 10:47 PM   #4 (permalink)
Wire muncher!
yeah, you'll need the .mbn (main firmware file). the .fbn file (the file system), and also the customisation files (custpack). you'll also need XS++ and/or SETools (depending on your phone) that completes the raw materials! i've never witnessed a k310i flash so i'm not sure whats the success rate. plz read about it, be sure and only then attempt.
firmware upgrade ? MambaXL Software Q&A 5 30-04-2008 03:50 PM
Is a firmware upgrade really necessary??? hsksattish Hardware Q&A 4 19-02-2006 09:53 PM
