Re: Mobile Network Sound
there is no solution for this unless the speakers employ electronic filters (which most prolly won't be the case). you can do nothing about it other than keeping your phone away from the speakers (mebbe on th side table or below it, somewhere in the drawers etc.
if you notice, the same thing is heard even on a wired landline phone instrument. however, now a dayz the newer phones haf built in filters for that frequency and are hence immune to it. it may take some time for the speakers to come up wid filter. till then you can't do much about it other than physically increasing the distance between the two.
