Old 27-09-2007, 10:36 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default electric shock from mobile...
Hi guys,
I'm using Nok-6233..and for the 2nd time..it is giving me a slight electric shock while attending a call AND BOTH THE TIMES IT WAS ATTACHED TO A PC USING USB. What would be the problem..?? Did any of u had similar experience...??
regards
Windchimes
windchimes is offline
Old 27-09-2007, 11:03 PM   #2 (permalink)
Back in Power
almighty's Avatar
Default Re: electric shock from mobile...
ya me too get these shocks
i use GPRS to surf and all the time my cell is connected to pc via data cable
if i touch cell while its connected via cable then i get a light shock
it basicaly coz of no earthing point in switch of ups....
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
Old 28-09-2007, 05:19 PM   #3 (permalink)
My Nokia 7610 also gives me a shock when connected with computer. Even my digicam does so.
Most probable reason: Earthing not done
ThinkFree is offline
Old 28-09-2007, 05:27 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Improper earthing is the root cause of all this. My sincere advice would be to get your place properly earthed so that not only the electrical point where your computer is connected but also all others are safe: for you, for your family and for all your devices.
infra_red_dude is offline
Old 28-09-2007, 05:40 PM   #5 (permalink)
AJJU
azzu's Avatar
i always get the SHOCK when i connect my SE to comp
btw :its fun i like that shock
its not so severe ull get used to it after days...
I love and Live to Design
azzu is offline
Old 28-09-2007, 06:54 PM   #6 (permalink)
dOm1naTOr's Avatar
yup, i enjoy dat shock from my digicam. Its sure not coz of improper earthing as its adapter has only two pins. So the company built it the way to be shocked.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 28-09-2007, 07:19 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Now that's very odd people, or is it?
QwertyManiac is offline
Old 28-09-2007, 07:23 PM   #8 (permalink)
>:)I-):(|)8-X
Charan's Avatar
^^ Rofl
i5 2400 | DH67BL | G.Skill Ripjaw 4 GB | FSP SAGA II 500W | CM 430 Black Elite | MSI R6850 Cyclone PE/OC | XBox 360 Controller | 21.5" Samsung Sync Master 2233 | 4 Mbps UL
Charan is online now
Old 28-09-2007, 07:26 PM   #9 (permalink)
It would happen if he touches any metallic part of the phone. He has mentioned that it happens when he makes a call when the phone is connected to pc
Old 28-09-2007, 07:29 PM   #10 (permalink)
AJJU
azzu's Avatar
soon ARVINFd and me will be havin a avatar similar to ASFAQ
azzu is offline
Old 28-09-2007, 07:32 PM   #11 (permalink)
>:)I-):(|)8-X
Charan's Avatar
You didnt get the humor in it .... read "Nature Call"
Old 28-09-2007, 07:41 PM   #12 (permalink)
Commander in Chief
Oh I misread that to be separate for calling and while connecting. Apologies.
Old 28-09-2007, 07:54 PM   #13 (permalink)
M$™ Certified Spammer
entrana's Avatar
i dont get shocks on me SE and Nokia and i have no earthing on my ups...?
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 28-09-2007, 08:01 PM   #14 (permalink)
dOm1naTOr's Avatar
@entrana
thank god u havn't been shocked yet. If u really wanna shock there are many easy ways than mobiles
G3: XPS M1530 |
FZ 16.
Old 28-09-2007, 08:43 PM   #15 (permalink)
respect mah authoritah!!
girish.g's Avatar
i ahev these shocks regularly on my PSP while charging so i let my friends play with it while its charging works for me now no one dares to touch my PSP
girish.g is offline
Old 28-09-2007, 08:48 PM   #16 (permalink)
i am sure ur pc have not correct earthing.please check.i have also same problem.
babuli_05 is offline
Old 29-09-2007, 02:26 AM   #17 (permalink)
Wire muncher!
ppl its not the device (like pc, ups, mobile etc.) that doesn't haf proper earthing. its the whole electrical setup which is at fault. get it checked.
regarding only 2 pin plug, you can't do anything about it. i guess we'll soon be seeing you on TV.. seen the havel's mcb ads??!
Old 29-09-2007, 08:53 AM   #18 (permalink)
Can you hear it..??
windchimes's Avatar
hi, i have them properly earthed and i have no probs with my pc to which it wqas connected......!!!
Old 29-09-2007, 09:35 AM   #19 (permalink)
AJJU
azzu's Avatar
ya anIRudh me too wud be there soon
azzu is offline
Old 29-09-2007, 10:44 AM   #20 (permalink)
100% Earthing not done, get it corrected, use spike with led on it which show you if Earthing is there or not.
Why don't you allow HTML signature?
Stick is offline
any electric charger for ZEN Microphoto 8 GB ? esumitkumar Hardware Q&A 3 22-08-2006 02:37 PM
MY COMP GAVE ME A SHOCK!! sahil_blues Hardware Q&A 9 26-03-2006 07:06 AM
help system shock 2 ratzee199 Gamerz 2 05-02-2006 11:22 PM
