Old 25-09-2007, 08:29 AM   #1 (permalink)
Exclamation Please help me!
I am using Nokia 6070 and BSNL Prepaid connection. My problem is, in phone screen the name of the operator is displayed two times.
I want to display the operator name in one times (like this "CellOne").
Please Help Me!
aneeshmohan is offline
Old 25-09-2007, 08:36 AM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Please help me!
Mostly you've enabled "Cell Info" or "Operator Info" or something like that. If the feature is correctly supported by your Operator, then it shows the area you're currently in!
Just turn it Off, Search the settings. (donno where exactly it is because I don't have a Nokia. In SE it is in Message Settings)
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 25-09-2007, 08:41 AM   #3 (permalink)
Cell information option is already "off" in my phone.
Old 25-09-2007, 09:51 AM   #4 (permalink)
krazyfrog
Posts: n/a
This sometimes happens with some operators. The name on the top is the operators name while the name on the bottom is the SIM name, i.e. the name saved in the SIM at the time of manufacture. This sometimes happens during roaming, when the phone displays the currently selected network on top and the SIM name on the bottom. But it can also happen in home network. Buying a new SIM might help. But a cheaper alternative is to use an operator logo which will cover both names. Better yet, use a blank logo.
Old 25-09-2007, 10:29 AM   #5 (permalink)
How can I use a logo?
Old 25-09-2007, 11:15 AM   #6 (permalink)
AJJU
azzu's Avatar
by downloading it simple
I love and Live to Design
azzu is offline
