Old 20-09-2007, 08:40 PM   #1 (permalink)
sagar_coolx's Avatar
Default earphones pour w810i
dudes i hav a se w810i and unfoRTUNATELY, MY EPS CONKED OFF (ONLY 1 CHANNEL WORKS?....SO NOW I HAVE 2 OPTIONS...
1.GET A STANDALONE EARPHONE SET..
2. BUY AN ORIGINAL HPM-70....
NOW WAT DO U SUGGEST?.. SINCE HPM 70 COSTS 1200, I FIGURE I MIGHT GE T A BETTER DEAL IF I BUY SEPARATE EARPHONES........
IF SO, WHICH EARPHONES SHOULD I GO FOR? WHICH WILL GIVE ME BEST AUDIO QUALITY WITHIN THE BUDGET OF 1200?FIRST HAND EXPERIENCE WELCOME THE MOST...
OTHERS,...HECK..U R WELCOME TOO
sagar_coolx is offline
Old 21-09-2007, 08:05 PM   #2 (permalink)
respect mah authoritah!!
girish.g's Avatar
Default Re: earphones pour w810i
what HPM-70 for 1200 where do you live i got it for 500
girish.g is offline
Old 21-09-2007, 08:08 PM   #3 (permalink)
AJJU
azzu's Avatar
^^^^ rght
I love and Live to Design
azzu is offline
Old 21-09-2007, 08:17 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
sony world sells hpm70 for ~1k. are you sure you get the original ones for 500? (with or without bill doesn't matter!)
@thread starter
since you already haf the bottom part of hpm70 for connecting standard earphones/headphones/headset you can think about creative ep630. they are selling like hot cakes. search the forum for reviews. its well in ur budget.
infra_red_dude is offline
Old 21-09-2007, 08:28 PM   #5 (permalink)
a_k_s_h_a_y's Avatar
hey the problem could even be due to the other half part
check that first man !!
connect it to your phone to comp speakers and u will know if its the earphone or the adapter is the problem !!
yes and go for Creative EP630 ! if u will buy a new one.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 21-09-2007, 09:58 PM   #6 (permalink)
dOm1naTOr's Avatar
It mostly happens when the cloth covering inside the hole is covered with dust nd dirt. I suggest u to take a needle nd remove the protection inside each earbud(both of them). This had happened to many of my frieands.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 21-09-2007, 10:45 PM   #7 (permalink)
no no...the lower connecter is perfectly fine...the probs with the earphone part only...
so reading the reviews, i think ep-630 will b good...
now the prob..
i live in mumbai, where from do i buy them so that i get original ones too...and at the lowest price too...
(this q has been asked b4, but found no unambiguous answer)
i understand alfa sells them without warranty...but then r they original?
Old 23-09-2007, 12:00 PM   #8 (permalink)
yeah even i would like to know where to buy ep630 even i am from mumbai.
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 24-09-2007, 10:13 PM   #9 (permalink)
is there not a single soul in this famed digit forum who
1.lives in mumbai
2.owns an ep630 set
Earphones napster007 Mobiles and Tablets 49 29-10-2007 04:53 AM
Pour in ur PC's Configuration ! BBThumbHealer Chit-Chat 4 31-05-2007 08:57 PM
[WTB]Earphones Maverick340 Hardware Q&A 6 10-01-2007 05:55 PM
In Ear earphones Keith Sebastian Mobiles and Tablets 5 09-07-2005 09:00 PM
