Old 17-09-2007, 08:44 PM   #1 (permalink)
Default need hlp nokia 6681
hellow, i have a nokia 6681 and i lost the cd which i use to connect, i downladd Nokia_PC_Suite driver and tried to connect it dosent connect ,
so any body please
suck is offline
Old 17-09-2007, 09:08 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: need hlp nokia 6681
I download and use too, but it works just fine. What method of connection are you using? Data cables tend to get loose at times. Try buying a cheap BT Dongle (200-300) and use it with N-PC Suite.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-09-2007, 10:50 AM   #3 (permalink)
raksrules's Avatar
Try to get the latest Nokia PC suite from the vendor's website. The newer versions are NOT phone specific and almost all phones can be connected via bluetooth / IR / USB Cable.
raksrules is offline
Old 18-09-2007, 06:37 PM   #4 (permalink)
i dont no, may i will try newer version
suck is offline
nokia 6681 vandit Mobiles and Tablets 3 24-03-2007 03:44 PM
Query abt Nokia 6681 and Nokia 3230 sidewinder Mobiles and Tablets 20 16-12-2006 12:21 PM
Nokia 6681 vs. 6630 pickster Mobiles and Tablets 19 28-11-2006 09:26 PM
Nokia 6681 R.I.P cyrux Mobiles and Tablets 4 17-11-2006 01:15 PM
